Go to Post Yup. Two world champs on one alliance, out in the quarterfinals. Only at IRI. - Norman J [more]
Unread 21-02-2005, 18:59
team222badbrad's Avatar
3D Printing Specialist
AKA: Bradley Rigdon
FRC #0222 (The Tigertrons)
pic: Sprocket mounting for window motor
Tigertrons are on Facebook!
http://www.printo3d.com
16th FIRST season for me.
Unread 21-02-2005, 19:04
Wayne C.'s Avatar Unsung FIRST Hero
Wayne C. Wayne C. is offline
hey- I think we did pretty good?
FRC #0025 (Raider Robotix)
Wayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond reputeWayne C. has a reputation beyond repute
Re: pic: Sprocket mounting for window motor
FYI-
A finding about the Nippon Denso Motors-
we used the ND motor as the axis of an articulated arm where the ND gear drives a larger gear in a simple gearbox. However we find that the housing of the axis of the motor is weak and tends to crack through the housing after a while.
We remedied the situation with a cleat and a little reinforcement of the shaft so it won't torque so much. Hopefully it will last well enough and after about a thousand trials over the past three days I think we are set.
WC
you want that robot to do what?
Raider Robotix- www.raiderrobotix.org
Unread 21-02-2005, 23:06
Scott team 48's Avatar
Scott team 48 Scott team 48 is offline
FRC #0048 (Delphi E.L.I.T.E.)
Scott team 48 is a jewel in the roughScott team 48 is a jewel in the roughScott team 48 is a jewel in the rough
Send a message via AIM to Scott team 48
nice job guys, any tips on getting the hole pattern right? we made a replacement for the plastic coupler out of aluminum and it took forever to get right. I would like to know if you have any tips for while we make extras during the "fix it" window. Thanks.
Unread 22-02-2005, 03:06
AKA: Bradley Rigdon
Well since I'm up past 2:45am on the Tuesday morning before ship putting it in the box; I might as well help you out.
First you need a 5/32 drill bit and then you can just follow this drill pattern once the sprocket is centered in the mill.
You will probably need a lathe to bore the hole to the size that the hole is in the plastic coupler.
I do not remember what size it is.
You will also need to chamfer the edges of the holes because of the way the gears are shaped on the motor.
If yah need anything just let me know being that I made them.
Sorry for the not so good drawing; I guess I should also specify that my units are in inches too.
Name:	sprocket gear pattern.JPG
pic: 870 Motor Mount CD47-Bot Robot Showcase 9 27-04-2004 11:55
pic: 571's new gearz loose weight CD47-Bot Robot Showcase 24 16-04-2004 16:35
pic: Fischer Price motor are very powerful CD47-Bot Robot Showcase 15 17-03-2004 20:22
need window motor pic!! Rickertsen2 Motors 3 04-02-2003 21:50
