Go to Post Believe that Dave knows what he is talking about. - JaneYoung [more]
Unread 22-02-2005, 02:49
pludodog pludodog is offline
College Student
AKA: Joe Hall
None #0395 (2trainrobotics)
pludodog is a splendid one to beholdpludodog is a splendid one to beholdpludodog is a splendid one to beholdpludodog is a splendid one to beholdpludodog is a splendid one to beholdpludodog is a splendid one to beholdpludodog is a splendid one to behold
Send a message via AIM to pludodog
pic: Team 395 - The Spicey!
jphiii
395 - 2trainrobotics
2005/06 NYC Champions
2005/06 Pittsburgh Champions
30 - Fury
Unread 22-02-2005, 02:52
College Student
AKA: Joe Hall
Re: pic: Team 395 - The Spicey!
Hopefully we weren't the only team driving around at 3am last night :-).
Surprisingly, just for fun... nothing actually broken.
Unread 22-02-2005, 03:09
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
We were working until 2am last night .. and 3:30am 2 nights before. So .. heh .. you're fine
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 22-02-2005, 05:30
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
Ahhh.... Just got back from the lab... we were finishing the animation.
We alternated playing one-eye catch, driving for fun, and working in 3DS max.
Now, for an hour of sleep, then school!
Unread 25-02-2005, 02:08
Alekat's Avatar
Alekat Alekat is offline
AKA: Alex
None #0701 (RoboVikes)
Alekat has a spectacular aura aboutAlekat has a spectacular aura about
Send a message via AIM to Alekat
Do you consider the wire hanging out the side of your arm a problem? We were a little scared with all the arms flying they might get snagged on our big loop of precious tubing and wire.
Unread 25-02-2005, 09:07
Joe Matt's Avatar
Joe Matt Joe Matt is offline
Wake Up Get Up Get Out There
Joe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond reputeJoe Matt has a reputation beyond repute
Aw, man, too bad you guys aren't coming to VCU this year.
Great bot, I'll be looking for you guys at Champs!
Unread 25-02-2005, 09:25
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
Great looking Robot!
Good luck to you guys this year!
Gene
- Gene Falendysz
Unread 25-02-2005, 11:19
i_am_Doug i_am_Doug is offline
Currently foraging for food..
AKA: Doug
i_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura about
Send a message via AIM to i_am_Doug Send a message via MSN to i_am_Doug Send a message via Yahoo to i_am_Doug
your arm is like a fishing pole....kewl
Unread 25-02-2005, 19:20
Waynep Waynep is offline
217 Alum, Former 395/348 Mentor
FRC #1923 (MidKnight Inventors)
Waynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond reputeWaynep has a reputation beyond repute
We do consider the wire loops hanging from the side to be a problem. Tips for you:
1. Try and keep the loops as small as possible with multiple tiedowns. When the crane is fully extended, the cable is pulled almost perfectly straight along the robot. Latex tubing is a simple way to keep the cables as close to your robots arm/crane.
2. We use split loom tubing to help protect the wire in the event of contact, but this still does not prevent entanglement.
3. You can also look into cable and hose carrier, http://www.kabelschlepp.com/ for example. To provide a neat way of managing your cables.
4. And perhaps most important of all is that if you have to have wires exposed, your drive crew needs to be aware of incoming robot arms and maneuver your arm/robot to protect your wires.
Hope this helps. Gene, Joe, thanks for the comments. Sparky and Metal in Motion produced some pretty impressive robots this year. I'll be looking forward to seeing the two of you at Nats. Good luck to all of you at Regionals.
Best,
Wayne
395 2TrainRobotics
Regional Champs- '03 VA, '05 PIT, '05 NY, '06 PIT, '06 NY; Regional Finalist- '04 NY; Engineering Inspiration- '03 NY, '06 PIT; Regional Chairman's Award- '04 NY
348 Norwell Robotics
2008 NY Regional Finalist; 2008 Curie Division Champs; 2008 World Championship Finalists
1923 MidKnight Inventors
2009 NJ Regional Champs; 2010 BOS Engineering Inspiration Award; 2011 CT Regional Champs, Gracious Professionalism Award, Coopertition Award
Unread 27-02-2005, 01:42
pikapuka's Avatar
pikapuka pikapuka is offline
AKA: The only animated mentor you'll ever know.
FRC #0395 (2TrainRobotics)
pikapuka is an unknown quantity at this point
Yayy, go Spicy!
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
**FIRST EMAIL**/Important December 3rd Deadline Information - Please Read! dez250 FIRST E-Mail Blast Archive 1 23-11-2004 13:35
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
pic: Another pic of Team 930 CD47-Bot Robot Showcase 7 25-02-2003 21:07
