Go to Post Robot gets bored during practice, wanted to listen to some podcasts. - Tom Bottiglieri [more]
Unread 22-02-2005, 04:26
pic: Wooden Thunder, Team 1294
Unread 22-02-2005, 04:29
elknise's Avatar
elknise elknise is offline
AKA: Erik Knise
FRC #1318 (Issaquah Robotics)
elknise will become famous soon enoughelknise will become famous soon enough
Re: pic: Wooden Thunder, Team 1294
I saw your robot at the practice competition in Bellevue. You had a nice looking bot and it seemed to drive and handle nicely. Great Job.
Unfortunatly for us, Issaquah, we found out our robot was 14 pounds heavy, but we still had fun.
Hope to see you at the Pacific Northwest Regional in Portland.
Elknise
Issaquah Robotics
Unread 22-02-2005, 12:44
Unsung FIRST Hero Woodie Flowers Award
Chris Fultz Chris Fultz is offline
My Other Car is a 500 HP Turbine
FRC #0234 (Cyber Blue)
Rookie Year: 1942
Chris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond reputeChris Fultz has a reputation beyond repute
Nice job, 1294.
You are making great use of the materials you have.
Good luck -!
Chris Fultz
Cyber Blue - Team 234
2016 IRI Planning Committee
2016 IndyRAGE Planning Committee
2010 - Woodie Flowers Award - Championship
Unread 22-02-2005, 13:01
JamesCH95's Avatar
Hardcore Dork
AKA: JCH
FRC #0095 (The Grasshoppers)
Props to you! Wood is a material very dear to my heart, but this is the first year our team hasn't used it. Looks like a solid bot, good work.
Unread 22-02-2005, 13:20
Alaina's Avatar
Alaina Alaina is offline
J = Pf - Po
FRC #0814 (Megaforce Squadron)
Alaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to behold
Send a message via AIM to Alaina
It's...so...beautiful!!!!
I love wooden robots! The most successful robot my team ever built was made of wood. But we haven't used wood for the past 2 years. I miss working with wood. =(
"It's cool to be a geek!" -- Dave Lavery
"It's all about the math." -- Mark Leon
Unread 22-02-2005, 17:28
george56 george56 is offline
the Beast of 116
AKA: Big G
FRC #0116 (epsilon delta)
george56 has a spectacular aura aboutgeorge56 has a spectacular aura about
Send a message via AIM to george56
NICE ROBOT! its very old-school to use wood. (not that tahts a bad thing ) looks pretty solid though.
Good Luck at the competitions!!
Unread 22-02-2005, 18:47
If we had a fully-equipped machine shop we might have gone that route, but we work in a woodshop and don't have a lot of money for paying someone else to do welding and machining, so we had to choose between wood and bolting together stock aluminum bits. My hobby is woodworking and I built a couple of sample components to show the students that wood can be light, stiff and strong if you design around its strengths. (For example, an 8-foot 2x4 weighs around 10 pounds. For comparison, a piece of solid aluminum stock a little over 1" square would weigh around the same -- but it would bend a lot easier. Of course, you wouldn't use solid aluminum bar stock, but we didn't use 2x4s either.)
Our towers are I-beams with 4-inch webs glued into .25-inch-deep grooves in the 2-inch wide flanges. We used zero-void 1/2-inch Meranti plywood. The two towers are joined by glued-and-screwed plywood panels for stiffness, and, frankly, to give us a big flat surface to decorate on the front. Blocks of pine are glued into the I-beams wherever we wanted to attach braces or the bearings for the arm mechanism. The bearings are captured by holes drilled into the insides of the pine blocks.
The electrical systems are mounted on 1/2-inch construction plywood and the tetra-gripping system is mounted on 1/2-inch construction plywood reinforced in key places with a second layer glued into place. If we hadn't been in such a hurry, we would have used 12mm Baltic Birch plywood.
The robot was built undersized to allow us to attach a bumper system within the 28x38 inch limit. To make sure we stayed within the box, we milled 1.25 inch side bumpers out of fir. The robot was a little too close to 38 inches to use this on the front and back, so we substituted 4/4 red oak. The corners are reinforced with heavy steel strapping usually used as a construction brace.
By the way, in the photo above, the tetra is being held over the back of the 'bot. We score on the other side.
Just thought you might be interested in some of the details of our Old School technology...
Unread 22-02-2005, 20:04
elknise's Avatar
AKA: Erik Knise
Why did you make your robot smaller to accomodate bumbers? Acording to R30 in 5.3.4 The Robot, Bumpers may extend outside the normal robot starting dimensions (in the horizontal plane) up to 4.” per side.
Elknise
Issaquah Robotics
Unread 22-02-2005, 20:36
Originally Posted by elknise
Why did you make your robot smaller to accomodate bumpers? Acording to R30 in 5.3.4 The Robot, Bumpers may extend outside the normal robot starting dimensions (in the horizontal plane) up to 4.” per side.
My bad. "Bumpers" in FIRST land are allowed to extend past the maximum size, but they have to be soft and removable for weighing and measuring. We were somewhat concerned about 130+ pound robots moving at 15fps smashing into our nice aluminum side rails, so we gave up the "free" soft bumpers in exchange for solid support for the rails.
This paid off in the Bellevue trial event when one of our own teammates smashed into our side. There is a 1/4-inch chunk missing from the side beam, but no damage was done to anything else.
Unread 23-02-2005, 15:14
elknise's Avatar
AKA: Erik Knise
Yeah it was really rough there, robots got stuck in our arm twice and that little one without an arm was just all over the place.
Elknise
Issaquah Robotics
Unread 23-02-2005, 19:07
Gabe Salas Jr.'s Avatar
Gabe Salas Jr. Gabe Salas Jr. is offline
Ri3D 1.0
AKA: CrazyBear
FRC #0233
Gabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant futureGabe Salas Jr. has a brilliant future
Wow, nice craftsmanship. Did you guys experiment with different types of wood such as Mohagany or Red Wood before settling on a couple of specific types of wood for the overall robot design? Was there another reason for choosing wood for the robot design besides not having a machine shop readily available?
"Confidence, not arrogance."
Does your robot use its powers for good, or for awesome?
Unread 23-02-2005, 21:40
First off, I might want to be your team when I grow up...
We didn't experiment because I already knew what we should use, and what we could afford. I've been a hobbyist furniture and cabinet maker for 15 years, and an amateur boat-builder for three. I already know the characteristics of different materials.
We used fir for the rail-protectors (don't want to call them bumpers) because it is strong, but resiliant. We want the wood to give a little in this spot or else we might have used oak, maple, or jarrah. All would have more impact resistance than fir, but they are much heavier and won't absorb as much of the impact energy. The front and rear are 13/16" red oak because I had some scraps laying around, and we were a little too long to use the 1-1/4 fir I had.
The tower is made from boat-building leftovers. I had a nice half-sheet of 1/2-inch marine-grade meranti. Again, in a perfect world I would have used 12mm okume for this (lighter), but that stuff costs $100 a sheet.
The tetra-grabber platform is fir construction plywood because that's what the arm team grabbed for the job. I would have used the okume -- or 12mm baltic birch -- but they wouldn't wait for me to get to the lumberyard to get some. Besides (recurring refrain) we already had the construction plywood on hand...
Our chassis is the KOP aluminum channel, and we used some steel tubing for arm components and the tower braces. The tetra grabbers are custom-fabricated steel and are our only welded pieces. The shaft for the arm is a steel tube captured in a pretty heavyweight piece of rectangular aluminum.
I think it's a nice blend of materials, and a great example of a decent robot built cheap. We think it will be a top-10 'bot at our regional.
Thanks everyone for the kind comments. I'll pass them along to the students. They built it.
The Death of FIRST Anton Abaya General Forum 23 03-05-2006 17:18
Kettering Kickoff Matt Attallah Off-Season Events 19 27-09-2004 22:40
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
Loss of Gracious Professionalism Among First Teams Melissa Nute General Forum 82 31-03-2003 19:34
