Go to Post Your best friends are all team members and you could never live without any of them because robotics people are the best people. - Riverdance [more]
Unread 22-02-2005, 10:58
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Re: Delay in autonomous mode
Originally Posted by SpeakerSilenced
Is there a simple way of delaying in autonomous mode?
At the top of your user_routines_fast.c:
static unsigned int sleeper = 0;
Where you want to delay:
if (sleeper > ???)
     /* code you want delayed */
else
     sleeper++;
For a simple autonomous mode, usually you structure your autonomous mode with a "switch/case" control block to seperate the different "sections" of your autonomous program. If you're doing this, make one of your sections the above delay, and under "code you want delayed" you place the code that moves you to your next "section".
-SlimBoJones...
a simple autonomous mode question chippermonky Programming 3 18-02-2005 01:54
A little question about the autonomous mode Anton Programming 4 18-01-2005 14:08
Future of Autonomous Mode FadyS. Programming 41 24-05-2004 19:45
autonomous mode problem on field Chris_C Programming 17 26-03-2003 19:11
