Go to Post Woodie once said he wanted to make our brains hurt. And I *don't* think he was talking about getting beaned by 198 grams of foam.... - Ken Patton [more]
Unread 21-02-2005, 18:42
krhs_programmer's Avatar
krhs_programmer krhs_programmer is offline
Programmer, Engineer, exDriver
#1247 (R.O.K.S.)
krhs_programmer is an unknown quantity at this point
Cheap circuit breaker
This saturday we were working on finishing our robot and we had to put heat shrink on a terminal going into the breaker box. So we took the wire of and put heat shrink on the terminal and put the terminal back on the breaker and one of our programmers torqued the bolt down. We he must have tightened it too much because the breaker selfdestructed. I took a picture of it but i have to wait till after the competition to develop it and then i will post it hear. There are no words to desribe what happened to this so don't ask for me to explain it.
Unread 21-02-2005, 18:46
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Cheap circuit breaker
Do you mean the big stud in the breaker panel? If so, which one, positive or negative? I've never seen inside this year's breaker panel but it is possible you may be able to open it and replace it with a plain ol' bolt.
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
I'm not sure what you're asking for...or were you just curious if its happened to other people?
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 21-02-2005, 18:49
#1247 (R.O.K.S.)
its the 20 amp breaker w/the red button that is usaually used to turn the bot on and off and i want to know if any one else has had this experience and any input on the subject.
Unread 21-02-2005, 18:56
Okay, you mean the 120 amp breaker. In that case, you should not attemp continued use of the unit. Replace it with the one from last year's robot (or even 2003) (they are the same) and/or order a replacement from IFI.
Unread 22-02-2005, 13:24
What you describe is a classic case of self inflicted wounds. I would bet that the case of the breaker was cracked during a previous operation and may have been just waiting for the next event. The breaker is manufactured such that the molded black material will hold the internal parts in alignment. If you crack the base the internals parts become dislodged. Check to see how you mount the breaker and you may find that the breaker sits across a frame member that flexes during robot motion or when hitting an obstacle. When the frame twists and bends, the breaker can't take the stress and small fractures will result. The next person to come along with a nutdriver or wrench can produce enough force to twist the electrical bolt which causes the case to shattter along the fractures caused earlier. If you can't be sure the frame won't flex than mount a small plate that the breaker can be attached to.
Unread 22-02-2005, 14:58
jrocket567 jrocket567 is offline
FRC #0617
jrocket567 will become famous soon enoughjrocket567 will become famous soon enough
we also had one of those self-inflicted wounds... anyone know where to get another one?? i know that ours will not pass inspection... Ive checked IFI, and a couple other sources... ive also called marine stores nearby (I have a similar one on my boat.. but its only 30A..) they only see them as 100 or 135A... any help/ideas will be appreciated.
Unread 22-02-2005, 15:53
I believe both MCM and Terminal Supply carry the 120 amp breakers.
Unread 22-02-2005, 18:00
dez250 dez250 is offline
54... What a good number!
dez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond reputedez250 has a reputation beyond repute
Send a message via AIM to dez250
If you are referring to the circuit breaker that is in the photo below yes it is the 120Amp Circuit Breaker and yes you can get it from Terminal Supply Company. I will try to find a part number for you.
[edit] well it appears the part nmber on it there is CB185120, i will check to see if that is the same as it is for TSC. [/edit]
[edit 2] You can get it from Terminal Supply Company via part number CB3-SM-120. They are on page 88 of their pdf catalog but there is no price listed. The website though is www.terminalsupplyco.com i hope this helps. [/edit 2]
Name:	120 amp breaker.JPG
-Michael Dessingue
Unread 22-02-2005, 18:57
FRC #0617
Thanks dez and Al.. will be ordering 2 of em tomorrow morning
Unread 22-02-2005, 19:17
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
<Shameless plug> If you are courious to know how it works ect, check the white papers section for the circuit breaker autopsy I did </Shameless plug>
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 23-02-2005, 00:04
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Take the broken one to competition and you can get a new one. Ours broke during install last year, and my order with terminal supply got lost, I never got the one I ordered. Our 2004 bot still has the 2003 breaker on it with a little (2003) battle damage. The new breaker went on the 2003 bot.
circuit breaker board oljomo Inventor 4 08-03-2005 10:57
Hi-Amp Circuit Breaker massinator Electrical 1 15-11-2004 16:22
Main Circuit Breaker Yan Wang Electrical 6 20-02-2003 10:23
120 A circuit breaker tbmantia Electrical 2 05-02-2003 12:30
circuit breaker archiver 2001 2 23-06-2002 23:18
