pic: The programmer needs some alone time with the robot!
Re: pic: The programmer needs some alone time with the robot!
don't we all? I would've stayed int there with my laptop, but i only had one can of soup...
The only problem with doing that is that my laptop's batteries run down after about two hours, and there aren't any AC outlets in the crate...otherwise, it would have been the perfect chance to work on autonomous mode.
Programmers do need time alone to program autonomous mode. I wish FIRST created a rule to leave programmers alone while they're programming autonomous
TRUE THAT!!!
Just make sure you remove any anti programmer devices such as
http://www.chiefdelphi.com/forums/sh...ad.php?t=34994 or they will not be in a good state in however many weeks to your comp.... |
#7
If the programmer is left alone and if there's something mechanically or electrically faulty, his time will be wasted. Or, worse, he'll try to fix it himself. ![]() This year I wrote an autonomous mode interpreter. It took longer than making a simple autonomous routine, but it paid off. The robot's autonomous actions are controlled by a simple text script, which anyone can write. Once I got the interpreter to make the robot perform repeatably, I stepped aside. The other mentors and team leaders took care of the scripting. |
#8
Post the code (after the competition if you are leary). Phil |
| How much planning goes into your robot? | Jnadke | General Forum | 41 | 29-01-2006 21:29 |
| pic: Robot? What Robot? | CD47-Bot | Robot Showcase | 13 | 10-04-2004 07:08 |
| team 25 robot pic | nuggetsyl | Robot Showcase | 12 | 21-02-2004 00:57 |
| THIS TIME TEAM 438 BALANCING ROBOT | archiver | 2001 | 1 | 24-06-2002 01:01 |
| How long should production time be??? | archiver | 1999 | 4 | 23-06-2002 23:16 |
