Go to Post Honestly, just when I thought FIRST had finally created an FRC game without any near universally-hated rules, they went ahead and made one in TM 1. - artdutra04 [more]
Unread 22-02-2005, 20:47
Karthik1's Avatar
Karthik1 Karthik1 is offline
830 Alumni
AKA: Karthik Chokkaram
FRC #1504 (Desperate Penguins)
Karthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to allKarthik1 is a name known to all
pic: The programmer needs some alone time with the robot!
"freedom is voluntary self control” Mahatma Gandhi
Unread 22-02-2005, 20:52
pakrat pakrat is offline
Rich Ross
no team (The Rat Pack)
pakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nice
Send a message via AIM to pakrat
Re: pic: The programmer needs some alone time with the robot!
don't we all? I would've stayed int there with my laptop, but i only had one can of soup...
Unread 22-02-2005, 21:03
Goobergunch Goobergunch is offline
FRC #1168 (Malvern Robotics)
Goobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to allGoobergunch is a name known to all
The only problem with doing that is that my laptop's batteries run down after about two hours, and there aren't any AC outlets in the crate...otherwise, it would have been the perfect chance to work on autonomous mode.
Unread 22-02-2005, 21:18
Bharat Nain's Avatar
Programmers do need time alone to program autonomous mode. I wish FIRST created a rule to leave programmers alone while they're programming autonomous
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 22-02-2005, 21:26
Rich Ross
TRUE THAT!!!
Unread 23-02-2005, 04:36
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
Just make sure you remove any anti programmer devices such as
http://www.chiefdelphi.com/forums/sh...ad.php?t=34994
or they will not be in a good state in however many weeks to your comp....
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 23-02-2005, 09:58
But you'd still have to figure out how to prioritize access to the robot. Competition between mechanical/electrical and software tasks is probably our biggest hurdle when trying to get everything done on time.
If the programmer is left alone and if there's something mechanically or electrically faulty, his time will be wasted. Or, worse, he'll try to fix it himself.
This year I wrote an autonomous mode interpreter. It took longer than making a simple autonomous routine, but it paid off. The robot's autonomous actions are controlled by a simple text script, which anyone can write. Once I got the interpreter to make the robot perform repeatably, I stepped aside. The other mentors and team leaders took care of the scripting.
Unread 23-02-2005, 10:35
phillutz phillutz is offline
FRC #0851 (The Froggers)
phillutz is on a distinguished road
I for one would be interested in seeing the interpeter!
Post the code (after the competition if you are leary).
Phil
How much planning goes into your robot? Jnadke General Forum 41 29-01-2006 21:29
pic: Robot? What Robot? CD47-Bot Robot Showcase 13 10-04-2004 07:08
team 25 robot pic nuggetsyl Robot Showcase 12 21-02-2004 00:57
THIS TIME TEAM 438 BALANCING ROBOT archiver 2001 1 24-06-2002 01:01
How long should production time be??? archiver 1999 4 23-06-2002 23:16
