Go to Post By the end of week six, I'm sick of looking at the robot enough that stuffing it in a bag is rather cathartic...:rolleyes: - 2544HCRC [more]
Unread 21-02-2005, 10:06
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Are your solenoids firing on their own?
Team 188 is trying to track down a pesky problem that ultimately results in SOME of our Festo Single Solenoids randomly firing once in a while.
Please post if you have Single Solenoids installed on your robot, and have experienced them randomly changing state, and meet the following criteria:
1) The solenoids that fire on their own are single solenoids
2) They only behave erratically when you try and keep and hold them in the energized state - if you keep and hold them in the non-energized state, they stay perfectly still
3) You notice the Spike controlling them DOES change state for no reason (The lights blip orange when they should be Red/Green/Off)
4) You can simulate the weird behaviour by quickly disabling your robot, then re-enabling it
5) Whenever the solenoid fires on its own, you notice that the Radio Modem light on the RC flashes red for a fraction of a second
I have posted another thread in the Control System forum, however I posted this message too because there may be teams desperately trying to troubleshoot what they think is a pneumatics issue.
-SlimBoJones...
Unread 21-02-2005, 15:51
DarkJedi613's Avatar
DarkJedi613 DarkJedi613 is offline
Running Riot
AKA: Patrick Cloke
FRC #0358 (Hauppauge Robotic Eagles) FRC #1493 (RPI/Albany High School)
DarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to beholdDarkJedi613 is a splendid one to behold
Send a message via AIM to DarkJedi613 Send a message via MSN to DarkJedi613 Send a message via Yahoo to DarkJedi613
Re: Are your solenoids firing on their own?
Are you dropping voltage at all?
2003 - 2006 President, Coach, Webmaster Team358.org
2008 Mentor, Team 1493
Team Search | (Updated: 1-16-08)
FIRSTsearch
Unread 22-02-2005, 16:44
Scott358 Scott358 is offline
Engineer/Mentor
AKA: Scott5736
FRC #5736 (Kingsmen)
Scott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really niceScott358 is just really nice
The Festo valves are air piloted, requiring min 30psi to operate properly.
If you are experiencing intermitent operation, you may be dropping below 30 psi at times.
Unread 22-02-2005, 18:33
Nitroxextreme's Avatar
Nitroxextreme Nitroxextreme is offline
Relation to Mrs. Steve
AKA: Jon
FRC #1626 (Falcon Robotics ; 190 (Gompei and The Herd))
Nitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to beholdNitroxextreme is a splendid one to behold
Send a message via AIM to Nitroxextreme
i dont know if it is the same with single solenoids
but we had the same poblems with double solenoids
our fixed was
take solenoid completely apart
take out piston inside
clean off gunk
replace internal piston
put solenoid back together
it will now work
"He needed a chuck norris lesson in FIRST"...."I will give him a round house kick to the face...with gracious professionalism"
Unread 22-02-2005, 19:11
occra 23.
AKA: ryo
None #1481
but does that explain the spikes?
i think you have a bad battery, bad connection to rc, or dropping voltage
Unread 22-02-2005, 19:13
Stephen Kowski's Avatar
BSEE, MSEE, JD
AKA: employed
make sure the backup battery is charged/ plugged in because it will mess up communications between oi & rc....
Unread 23-02-2005, 02:09
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Actually, the RC will communicate with the OI without the backup battery. Just make sure the main battery is charged (with 11+ volts in it - you can check it by hitting the select button on the OI a few times). However, the 7.2v backup battery is reponsible for running the pwm signals to the victors.
As for the solenoid problem, it sounds like you have a short in your wiring somewhere, or maybe something wired to the spike/relay block wrong. Check all your connections, use an ohm meter to make sure theres NO continuity on your bot, and check the PWM/relay cables. It seems that we got a few bad ones this year. After you finish checking everything, find another electronics specalist on your team to check it over again.
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 23-02-2005, 04:19
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
If you have a dead backup battery, it messes around with the RC. Also, when you mentioned about quickly disabling/enabling -- the RC sets every output to its default value (127 for pwm's, 0 for digitals, etc... I think), mainly for safety reasons.
In 2004 we used pneumatics to move our arm and, occasionally, the solenoids would rapidly flicker (you could actually hear it) when the joystick was moving/moved back to its center position. I just assumed it to be the joystick not fully returning to the center position, but in some occasions it just did it at random, regardless of joystick position. It never really bothered us enough to try and find the problem. But that only applies if you're using a joystick to control pneumatics.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
How does your team wire your Double Solenoids? Doug G Pneumatics 14 17-02-2005 23:25
Controlling Solenoids With Victors Brandon_Cmpvir Electrical 20 16-03-2004 10:21
Is there any restrictions on buying solenoids hello world Electrical 1 01-02-2004 12:04
solenoids from last year Antonio Pneumatics 6 29-01-2003 22:59
solenoids zarb Electrical 1 28-01-2002 23:19
