Go to Post You guys must sponsor that one team on The Fosters! - Tyler Olds [more]
Unread 23-02-2005, 02:48
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Re: "Load Bearing Surface"
This is bizzare, i think they should change the triangles to rectangles or squares. Look at this picture from the manual, although its specifically mentioning to the human player requirements; it gives a big O.K to the loading process. Now look closely the robot is stradling the trianlge. This is a big blunder by FIRST, they should have never used this picture, our team might be able to add a load bearing surface but what about the other teams do. FIRST should be more considerate about this. Even till now its not crystal clear as to what the rules are regarding stradling. I know FIRST has done a great job creating a spectacular game, but i think they should make it better by changing or atleast not conflicting with their own diagrams.
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Ratchet/slip bearing? Ianworld Technical Discussion 6 20-01-2005 13:04
Looking for 1/2" id flanged bearing .25" thick or less (with flange) Travis Covington Technical Discussion 17 12-12-2004 21:26
bearing help jimfortytwo Technical Discussion 9 01-05-2004 06:20
Need A 0.75" ID bearing .DWG Tytus Gerrish Inventor 6 22-10-2003 11:23
Bearing support - Official Mike Martus OCCRA 0 24-09-2002 05:26
