Re: pic: Rachel climbs a tree... 1018
that lifting arm must weigh a ton!
it looks like its bending a little though... evidently you can reach at least 10 foot, have you ever fallen over? |
how fast does the arm go up???
and how heigh does your ceiling go up??? great job though again ![]() |
As far as bending is concerned... the runout on the arm isn't more than about 2-3 inches at full extension... but we will rarely extend it fully either...it is designed to be used at about 2/3 extension...at that point the runout isn't more than half an inch or so... ![]() Last edited by Bob Steele : 23-02-2005 at 10:04. |
Actually the arm (the horizontal portion) only weighs about 16 lbs. (including the hook and the motor) We don't intend to drive around much with it all the way up in the air. The whole robot weighs in at slighty less than 119 lbs.
The tower and the drive train are NBD... (Nothing but Dewalts...) Chip motors with Dewalt transmissions... We used a globe motor and a rack and pinion system to move the tower arm... I believe that the entire robot is simple but quite elegant in its design approach. thanks B Last edited by Bob Steele : 23-02-2005 at 10:04. |
| pic: Devils' Tower - 1018 | Bob Steele | Robot Showcase | 14 | 22-02-2005 19:08 |
| pic: Canadian Family Tree | CD47-Bot | Extra Discussion | 2 | 09-05-2004 00:16 |
| pic: 1018 Final Config. | CD47-Bot | Robot Showcase | 17 | 24-02-2004 22:10 |
| pic: 1018 OmniWheels - 1st generation | CD47-Bot | Robot Showcase | 7 | 19-02-2004 16:42 |
| pic: 1018 - Teaser #1 | CD47-Bot | Robot Showcase | 3 | 19-02-2004 16:21 |
