Go to Post Its not about Poof balls or green lights or getting up on the ramp at the end, this is about the learning experience and inspiration gained throughout the year. - Winged Wonder [more]
Unread 23-02-2005, 09:34
Bob Steele's Avatar
AKA: Bob Steele
pic: Rachel climbs a tree... 1018
Unread 23-02-2005, 09:37
Bob Steele's Avatar
AKA: Bob Steele
Re: pic: Rachel climbs a tree... 1018
This is the Devils' Tower in action...late Monday night...
It seems to be quite steady and smooth in its climb to the heights.
Designed by the Pike RoboDevils' Engineering Team.. and it will be featured at the Boilermaker Regional and at IRI in the summer. (Unless we some kind of $$$ miracle, we will not be able to go to Atlanta...)
Good luck to everyone!!! It was a GREAT build!!
Unread 23-02-2005, 09:38
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
that lifting arm must weigh a ton!
it looks like its bending a little though...
evidently you can reach at least 10 foot, have you ever fallen over?
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 23-02-2005, 09:41
tiffany34990 tiffany34990 is offline
tiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond repute
Send a message via AIM to tiffany34990
how fast does the arm go up???
and how heigh does your ceiling go up???
great job though again
Unread 23-02-2005, 09:42
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
Is that a scale on the floor?
Is it accurate?
Our team needs a better solution for weighing during the build.
What'd that one cost? Brand? Model #?
Incidentally, what does that sweet lookin' machine weigh?
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Bob Steele's Avatar
AKA: Bob Steele
Actually the arm (the horizontal portion) only weighs about 16 lbs. (including the hook and the motor) We don't intend to drive around much with it all the way up in the air. The whole robot weighs in at slighty less than 119 lbs.
The tower and the drive train are NBD... (Nothing but Dewalts...)
Chip motors with Dewalt transmissions... We used a globe motor and a rack and pinion system to move the tower arm...
I believe that the entire robot is simple but quite elegant in its design approach.
thanks
B
Unread 23-02-2005, 09:44
Stu Bloom's Avatar
Stu Bloom Stu Bloom is offline
I REALLY want to be Andy Baker
FRC #1018 (RoboDevils)
Stu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond reputeStu Bloom has a reputation beyond repute
Send a message via AIM to Stu Bloom Send a message via Yahoo to Stu Bloom
Our final weight is right on target. The tower secitons are cut from .100 thick aluminum sheet and weigh about 10.5 lb each. The arm is another 16 pounds. The tower is raised by one CIM/Dewalt combo using cascading style cables, and the arm is operated by a globe motor with a rack and pinion arrangement. The tower raises to full height (13 feet to the top of the arm) in 4-5 seconds.
Stuart Bloom
Mechanical Engineer
Rolls-Royce Corporation
FIRST Team 1018 - Pike HS RoboDevils
My activity for 2012:
  • Boilermaker planning committee
  • Israel Head Ref - DONE (and it was FANTASTIC!)
  • Boilermaker Regional (with 1018) - DONE
  • Midwest Head Ref - DONE
  • WORLD Championships (with 1018) - DONE
  • IRI Head Ref - DONE
  • CAGE Match Head Ref
Unread 23-02-2005, 09:45
Bob Steele's Avatar
AKA: Bob Steele
The arm goes up relatively fast. We have some difficulty with a tetra getting to the complete height. We will try to optimize that at the regional. But it has gotten high enough to cap a tall goal with 3 tetras on it..( that is the design parameter) The ceiling in that room is around 15 feet or so... It is the only room we could test it in...smile
As far as bending is concerned... the runout on the arm isn't more than about 2-3 inches at full extension... but we will rarely extend it fully either...it is designed to be used at about 2/3 extension...at that point the runout isn't more than half an inch or so...
Unread 23-02-2005, 09:51
Bob Steele's Avatar
AKA: Bob Steele
Is it accurate?
The scale is a TANITA BWB-800A Class III scale.
We purchased it at the beginning of last year's season... I believe we paid somewhere around $350 for it... maybe less... it was purchased online.
It has come in extremely handy for both FIRST and BEST robotics... it has a top end of 300 lbs and reads to .2 lbs.... We just put a board on top of it and drive or push the robot up on the board after zeroing the board out... works great!!! Every team should have one... We weighed during our rookie year by moving the robot down to the wrestling room (a loooooong way...) and using their scale... now we use this one... and its battery run so we can move it easily... if you need any other info please let me know
pic: Devils' Tower - 1018 Bob Steele Robot Showcase 14 22-02-2005 19:08
pic: Canadian Family Tree CD47-Bot Extra Discussion 2 09-05-2004 00:16
pic: 1018 Final Config. CD47-Bot Robot Showcase 17 24-02-2004 22:10
pic: 1018 OmniWheels - 1st generation CD47-Bot Robot Showcase 7 19-02-2004 16:42
pic: 1018 - Teaser #1 CD47-Bot Robot Showcase 3 19-02-2004 16:21
