Go to Post Hey, I'm not my dad, I dont know anything! - Lil' Lavery [more]
Unread 22-02-2005, 21:36
Robby's Avatar
Robby Robby is offline
AKA: Kevin Beranek
FRC #0269 (Cooney Robotics)
Robby has a spectacular aura aboutRobby has a spectacular aura about
Compiler Optimizations
Has anyone used the compiler optimizations? If so, which have you used? and have you had any problems with them?
I recently ran out of space on the controller, I rewrote quite a bit of code to optimize it, i got rid of all the unnecessary stuff and continued coding. I then ran out of space again. There is very little that i can do to compact my code even further, so i decided to try the compiler optimizations. I managed to get a significant improvement in size, from 99% to 89%, but i was wondering if there is anything i should be aware of, as i have not yet tested the new code on a robot. Is there anything that the compiler does in optimizations that might mess stuff up?
Unread 22-02-2005, 21:42
Umm Errr...
Re: Compiler Optimizations
For FIRST purposes, optimizations don't really present any special problems unless you are doing special things like debugging inline assembly.
1139 Alumni
Unread 23-02-2005, 01:29
if you enable all the compiler optimizations, make sure that anything volatile is declared volatile explicitly. You can get away without it with no optimizations (at least some times), but not with all the optimizations enabled.
I fought that at least a few times this weekend.
Unread 23-02-2005, 11:26
Don Reid Don Reid is offline
Don Reid will become famous soon enough
If you are running short of data space (RAM) be sure to declare the command_list array in commands.h as "rom".
Don Reid
Unread 23-02-2005, 11:36
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Probably a good idea even if you're not short on RAM, since it will take up space in FLASH regardless of whether it's declared "rom" or not.
Nasty Compiler Bug Matt Leese Programming 5 18-02-2005 18:44
using alternative compiler Leav Programming 2 18-01-2005 15:30
IMPORTANT regarding the new C Compiler dlavery General Forum 12 14-01-2005 05:05
Makefile and stripped down compiler Venkatesh Programming 0 09-01-2005 18:55
C compiler for 2004 Tim Skloss Technical Discussion 11 05-11-2003 22:02
