Go to Post Disclaimer: I am not an electrical engineer nor an electrician. I occasionally play one on CD. And when inspecting robots, sort of... - jvriezen [more]
Unread 23-02-2005, 10:44
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
pic: 1257 Finished
Team 1257
Unread 23-02-2005, 10:49
russell's Avatar
russell russell is offline
#1430 (WRONG)
Team Role: Electrical
russell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to allrussell is a name known to all
Re: pic: 1257 Finished
Wow thats cool. What appears to be one of those cool drive systems, a cool looking arm driven by the FP motors (have you had any trouble with those?), and just a generally nice looking robot. Good job. Have you weighed it though? It all looks pretty heavy, especially with all the bolts you used to attach everything. In any case though it looks great.
Unread 23-02-2005, 11:01
i_am_Doug i_am_Doug is offline
Currently foraging for food..
AKA: Doug
i_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura about
Send a message via AIM to i_am_Doug Send a message via MSN to i_am_Doug Send a message via Yahoo to i_am_Doug
mmmmm, is the clam gonna still be there?
Unread 23-02-2005, 11:11
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Do you plan to use Zip Ties on all those extra wires?
Unread 23-02-2005, 12:44
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
Those triangles in the arm were done with hand tools?! Wow, I envy your patience.
-Paul
Unread 23-02-2005, 13:05
Fold em oval!
Plotted out a template with center marks for the fillets. Drilled holes with ~1/2" bits. Jig sawed the lines between the holes. There are usually several people doing nothing, so it gave them a job...
Team 1257
Unread 23-02-2005, 14:22
Fold em oval!
It's around 100 lb, as the description says. All the 1" square tube is 1/16" wall, not the 1/8" wall that seems to be more common on FIRST robots. I had planned on riveting lots of the structure, but there was so much that we decided we'd like to be able to remove easily "just in case".
Team 1257
Unread 23-02-2005, 17:37
occra 23.
AKA: ryo
None #1481
gotta love how the compressor is also at a 45* angle. i was wondering where all the 4wheel omnis would be coming out.. after all we have 4 of the same good motor this year
Unread 23-02-2005, 17:43
Alaina's Avatar
Alaina Alaina is offline
J = Pf - Po
FRC #0814 (Megaforce Squadron)
Alaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to beholdAlaina is a splendid one to behold
Send a message via AIM to Alaina
I hope that C-clamp isn't permanent. =P
"It's cool to be a geek!" -- Dave Lavery
"It's all about the math." -- Mark Leon
pic: FINISHED!!!!!! Coachmac Robot Showcase 6 21-02-2005 21:10
pic: 1073 Finished Robot Petey Robot Showcase 5 13-02-2005 00:57
pic: Team #93's robot finished. CD47-Bot Robot Showcase 12 16-03-2004 19:32
pic: Team 930 2004 Robot Finished CD47-Bot Robot Showcase 1 16-03-2004 00:18
pic: 1083 Finished! CD47-Bot Robot Showcase 17 08-02-2004 15:46
