Go to Post 99.9999% of the FIRSTers are really nice - Denman [more]
Unread 23-02-2005, 09:31
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
cap high or fast
would you rather be able to cap high or fast. And please do not put down you do both unless you have video to prove it.
Unread 23-02-2005, 09:36
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
Re: cap high or fast
if i had t o chose one, i would say fast. You can also use your arm to stick them under the goals if you need to and if there are 8 goals (say you cant make the center but can get one or two on the others ) then there is still plenty of oppurtunity for getting points. I hope ours can do both but we havn't had a center goal or more than 3 tetras to test it out on...
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 23-02-2005, 09:48
OneAngryDaisy OneAngryDaisy is offline
not on CD enough...
OneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of lightOneAngryDaisy is a glorious beacon of light
Looking at the past games:
2003: much alike this year's game, except with stacking tetras.. many teams designed to be able to stack high, but in the end you rarely saw any teams stack at all. The game turned in a pushfest and who could control the bridge.
2004: Hanging/Capping: more teams turn to hanging than capping
2005: A fast, strong robot can almost always prevent a robot from picking up a tetra and capping it- or can it? I don't think there will be the need to stack high, stack fast, definitely, but not stack high.
so I'd take being able to stack fast.
Unread 23-02-2005, 09:51
tiffany34990 tiffany34990 is offline
tiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond repute
Send a message via AIM to tiffany34990
ya, i agree fast is better than high. the quicker you can put up one is better since you can hopefully get it up before someone pushes you to stop you. there are so many goals so you can always stack more.
Unread 23-02-2005, 10:06
Ryan M. Ryan M. is offline
Programming User
FRC #1317 (Digital Fusion)
Fast for me.
Unread 23-02-2005, 14:24
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Fast is defenitly the priority. If you're fast and can cap all the shorter goals with a reasonable number of tetras you'll be able to get 3 pointers for every tetra stacked and still be able to complete half of the rows available. If one robot on your team can outstack the others in terms of height, leave it to stack the center goal at the end the match to deal with the other 4 rows.
Team Website
Unread 23-02-2005, 14:54
Matt Adams's Avatar
Matt Adams Matt Adams is offline
b(o_o)d
FRC #1525 (Warbots)
Matt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond reputeMatt Adams has a reputation beyond repute
Send a message via AIM to Matt Adams
Post Re: cap high or fast
I'm going to sort of go out on a limb... and say that the winners are going to be who have the best tetra capping per second speed, assuming that they can't be pushed easily.
I don't see this becoming a game that's revolving much around that center goal either. Robots that get 5 or 6 tetras each round will be great to go, wherever they are.
:: Throws Out Some Bait ::
Scoring fast is the most important key to this game.
:: / Throws Out Some Bait ::
Matt
Matt Adams - Engineer at Danaher Motion
Team 1525 - Warbots - Deerfield High School
Unread 23-02-2005, 15:03
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
We can do both, but if I had to choose I would say fast. Because I have a feeling it will be difficult to cap a goal if someone else is messing around with you. So the quicker the better
Unread 23-02-2005, 15:13
Collmandoman Collmandoman is offline
Post-A-Holic
Collmandoman has a spectacular aura aboutCollmandoman has a spectacular aura aboutCollmandoman has a spectacular aura about
fast for the regionals ~ high for the championship~
capping the last can be as much as a 43 point swing
Unread 23-02-2005, 15:14
Swampdude's Avatar
Swampdude Swampdude is offline
AKA: Dan Quiggle
FRC #0179 (Children of the Swamp)
Swampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond reputeSwampdude has a reputation beyond repute
Yeah I'm thinking a bot scoring 5-6 average per match is going well into the finals. I think the final matches will consist of a bot on each team scoring in the range of 8 per match. I already started a poll based on this yesterday
It's looking like folks think 2-6 will be the average, I think that's a little high. I'm guessing more in the range of 2-3 per team per match "average". But speed is definitely the key.
Edit: I also think no 1 team will score more than 14 in a match. I also think the best teams will max out at 10 per match. And your highest alliance score will be around 24.
www.179swampthing.org
Unread 23-02-2005, 15:30
Petey's Avatar
Petey Petey is offline
Strategy & Gaming
AKA: Chris Peterson
None #1073 (Team F.O.R.C.E.)
Petey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond reputePetey has a reputation beyond repute
Ignoring the fact that it is only necessary to stack high if you can stack fast, I would say fast.
Two years in FIRST have proven to me that success can always be found in a high-volume, high speed robot, whereas a bot that goes for broke once in a while goes broke more often than not. That is why I am worried for this year--it is much more difficult to do a "high volume" robot this year, and we're really facing a new paradigm as a team.
Our bot, Taurus, is quite different from our successful ball gatherer from last year, Scorpius. Hopefully, it will still be successful.
--Petey
Bio:
Team 1073 alumnus, now Admissions Officer at MIT.
Thanks to all those who have helped me through FIRST over the years.
Unread 23-02-2005, 16:21
fefie's Avatar
fefie fefie is offline
The Metetron
None #1304 (Nobotics)
fefie is an unknown quantity at this point
I think scoring fast will be the best bet, but I also think you should have a plan as to what spots you want to put the tetras on. So think swiftly and wisely!!!
Unread 23-02-2005, 16:29
Yan Wang's Avatar
Yan Wang Yan Wang is offline
Ithaca is Gorges
AKA: John Wayne
FRC #0639 (Code Red Robotics)
Yan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud ofYan Wang has much to be proud of
Send a message via ICQ to Yan Wang Send a message via AIM to Yan Wang Send a message via MSN to Yan Wang Send a message via Yahoo to Yan Wang
Define "high".
Code Red Robotics Team 639 Alumnus | www.team639.org
<Patrician|Away> what does your robot do, sam
<bovril> it collects data about the surrounding environment, then discards it and drives into walls
Unread 23-02-2005, 16:49
psych0gambit's Avatar
psych0gambit psych0gambit is offline
AKA: me
FRC #1270 (Red Dragons)
psych0gambit has a spectacular aura aboutpsych0gambit has a spectacular aura aboutpsych0gambit has a spectacular aura about
Send a message via AIM to psych0gambit
im not sure what our robot can do but i would like it to cap fast. i know that our robot can store tetras on the back of it so it would be nice to quickly stack them and then collect more. It would be nice to stack high so we can get more tetras on the goals but there is only 2 minutes in the game so i would prefer stacking quickly.
Unread 23-02-2005, 16:59
Goober!!!'s Avatar
Goober!!! Goober!!! is offline
I am The Goober!!!
AKA: Steve
FRC #1501 (Team Thrust)
Goober!!! is a jewel in the roughGoober!!! is a jewel in the roughGoober!!! is a jewel in the rough
Send a message via MSN to Goober!!! Send a message via Yahoo to Goober!!!
Talking Re: cap high or fast
"Fast is GOOD!!! " so i say fast
Indiana FIRST 2005 line up Kyle Love Regional Competitions 4 04-11-2004 00:04
What does the Chairman’s Award have to do with a robot contest? Ed Sparks Chairman's Award 32 15-02-2004 13:39
Sacramento Regionals Hermione692 Regional Competitions 57 03-04-2003 02:29
St. Louis anyone? Jeremy_Mc Regional Competitions 8 07-02-2003 12:06
