| View Poll Results: You can locate the vision tetra and you... | |||
| ... used Auto Servo Mode |
8 | 50.00% |
| ... didn't use Auto Servo Mode |
8 | 50.00% |
| Voters: 16. You may not vote on this poll | |||
Re: Did you use Auto Servo Mode?
The basic gist of it is that you use a manual mode to execute a search pattern for the tetra. When you find it, you switch to autoservo mode. If you lose it, you go back to the search pattern. It's fairly simple and worked rather well for us. The autoservo mode is quite good and provides a really easy way of working with the camera.
That said, we dropped the camera when we realized that we wouldn't have enough time in autonomous to find and cap with it (that whole falling over thing doesn't help much). Matt |
Auto Servo Mode serves it purpose quite well. We used a basic counter loop that incremented the position of the pan servo and when we got a good T-Packet we swapped it over to auto track mode.
My one attempt at writing my own servo control ended when I got annoyed with the compiler over a stupid error. Later I figured out what the error was, but I didnt have time to fix it, and anyway I had working code using autoservo and just turning the whole robot to scan the field. It works really well (except for being disabled before autonomous and thus wasting time) but we still probably wont use our camera as I never did get around to testing our autonomous program.
| Auto mode help..... | Moloch | Programming | 2 | 18-02-2005 09:18 |
| a simple autonomous mode question | chippermonky | Programming | 3 | 18-02-2005 01:54 |
| Future of Autonomous Mode | FadyS. | Programming | 41 | 24-05-2004 19:45 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| autonomous mode problem on field | Chris_C | Programming | 17 | 26-03-2003 19:11 |
