Go to Post everyone here has a life outside of FIRST (some just don't want to admit it). - shyra1353 [more]
Unread 21-02-2005, 13:47
Fishdude404's Avatar
Fishdude404 Fishdude404 is offline
The fish king!! MUHAHAHAHAHAHAHAHAH
AKA: Andy Hsiao
None #1510 (Westview Robotics)
Team Role: Scout
Fishdude404 is an unknown quantity at this point
Send a message via AIM to Fishdude404 Send a message via MSN to Fishdude404 Send a message via Yahoo to Fishdude404
Button # limits?
I"m putting on the buttons for the operator interface, but the programming team says that we can only have 4 buttons per joystick port. Is that right? or can you change the number of buttons per joystick port?
----My Setup----
-Tippmann A-5
-E-grip
-J&J 14" Ceramic Barrel
- Two wrongs don't make a right, but three lefts do
- If I agreed with you, we'd both be wrong
- Happiness is like peeing in your pants. Everyone can see it, but only you can feel it's warmth.
Unread 21-02-2005, 14:01
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Button # limits?
Four is the easy limit. You could do a setup with switches and resistors on either the wheel or aux analog port to get more switches, like the hat switch on the KOP joysticks, but it'll be a lot of work for you, and it's a little trickier for the programmers.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 24-02-2005, 03:56
You have a total of 16 digital inputs on the OI. 4 are availible on joystick 1, 8 availible on joystick 2 (the same 4 from joystick 1 and 4 new ones). 4 are availible on joystick 3 and 8 are availible on joystick 4 (the same 4 from joystick 3 and 4 new ones).
If you are building a custom button box, you could always use 2 cables. One year, we even ran the two joysticks into our button box, and had 4 output cables, so we could get more buttons.
Like Joey said, you could also use a resistor ladder to hook multiple digital switches to an analog input.
Make sure to read the OI reference guide: http://www.ifirobotics.com/docs/oi-r...de-2-21-05.pdf
Joystick Hat button ten3brousone Programming 8 20-02-2005 13:31
IFI Loader and PROG button Dave... Programming 3 20-02-2005 12:03
One button wonder Fourevilmonkies Programming 8 10-02-2005 14:39
disabling a button gomez6760 Programming 1 12-08-2004 11:54
which button machine do you use and do you like it? KenWittlief General Forum 10 16-10-2003 00:01
