Go to Post Would all you teams please stop! My chin will be bruised for weeks from dropping on the floor so much. - GaryVoshol [more]
Unread 24-02-2005, 11:42
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Inversion of the digital IO pins
I was hoping to use an external EEPROM to store data for our autonomous routine, it uses an I2C interface, but I have code written to bit-bang, so that is ok, but here is my question. I know the pins are inverted as an input, since when they are low, you get a 1 in software, and when they are high, you get a 0. But are they inverted as outputs too?
Thanks
Unread 24-02-2005, 12:48
Re: Inversion of the digital IO pins
Thanks
They're not inverted in my experience, as either input or output. You might be thinking of the fact that they're internally pulled up to 5 volts, so a switch to ground reads as a logic 1 when it's open and a logic 0 when it's closed.
Unread 24-02-2005, 13:01
Ryan Cumings's Avatar
Ryan Cumings Ryan Cumings is offline
Programmer and University Rejected
#0134 (Team Discovery)
Ryan Cumings is an unknown quantity at this point
Send a message via AIM to Ryan Cumings
I thought that a pull up floated high which meant that it will always read as a logic 1 unless you ground the signal pin
Suddenly being rejected from college feels right during the build season. Now I am a mentor.
Unread 24-02-2005, 13:37
You thought correctly. As I said, closing the switch to ground yields a logic 0.
Unread 24-02-2005, 16:06
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
A pullup does not imply inversion. It just means that when you leave it floating, you will get a logic one on the input. If you have an input connected to it that will pull the input down, then you will get a logic zero as the input.
Matt
Unread 25-02-2005, 12:41
Team Alumni
Nevermind, limit switches, use OPEN and CLOSED, not a bit test... bah sorry
Its been a long 6 weeks... (*mutters on about being designer, team leader, and programmer...*)
I thought that they made it so that when the switch was closed, the bit read 1, and when it was open it read 0.
in user_routines.h
#define OPEN        1     /* Limit switch is open (input is floating high). */
#define CLOSED      0     /* Limit switch is closed (input connected to ground). */
I guess I won't have to modify my programs after all...
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
Dynamic Input/Output Changing Paolo Control System 6 23-09-2004 19:09
[ECDU]: CHAT-7/19 Corey Balint FIRST-related Organizations 5 19-07-2004 23:44
digital inputs not valid just after initialization? WizardOfAz Programming 2 26-01-2004 13:21
