Go to Post FIRST is nothing short of a community. - karinka13 [more]
Unread 20-02-2005, 17:21
brandon.heller brandon.heller is offline
brandon.heller is an unknown quantity at this point
Dewalt/FP gearbox "sticking" in reverse
Hi,
My team is having a problem with a rotating Tetra-grabbing arm. We have a Dewalt/FP combo, standard as per the great white paper, driving a 4' arm through a ~23:1 ratio, in low gear at the drill clutch setting. The setup lifts a tetra just fine, but in reverse, the arm often sticks. It refuses to go down for a bit, but by pushing up, then down, on the control stick, it comes down. It also make a horrible clutch-grinding-type noise as it comes down.
-the problem happens only when a tetra is on the arm
-a swap to a different motor and drill combo had the same result
-it's not programming
We think it might be the dewalt clutch anti-backdrive pins getting stuck on the way down. We don't want to lose those pins, though - the arms stays in place, fully horizontal, while holding a tetra.
Any ideas?
Thanks,
Brandon Heller
team 931 mentor / 449 alum
Unread 20-02-2005, 18:01
jimfortytwo jimfortytwo is offline
AKA: Jim Paulos
#0418 (Purple Haze)
Team Role: Student
jimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nicejimfortytwo is just really nice
Send a message via ICQ to jimfortytwo Send a message via AIM to jimfortytwo Send a message via Yahoo to jimfortytwo
Re: Dewalt/FP gearbox "sticking" in reverse
We too are using a dewalt on our arm, and it is working very well for us. Let me relate our experience, and maybe some of it might apply to your case. We have a 60" arm that takes a tetra on the far end of it, and is driven by a 6" sprocket bolted to the arm. Initially that sprocket was linked 1:6 to a small pinion on the dewalt. We discovered that we were pulling too many amps in this format, and the arm was way too fast. Additionally, it seemed like the arm would slip and catch when power was taken away-- the backdrive pins were holding, but it wasn't confidence inspiring.
To lower our speed and amp draw, we added a second 1:5 reduction. Now the large drive spocket on the arm leads to a small sprocket on an intermediate axle, which is common to a second large sprocket which is then linked by chain to our dewalt. In other words, two loops of chain as reduction between the arm and the dewalt. Now our speed is right where we want it, and we can run our motors on the 20A breakers without poping them.
We had a binding problem. We could lift fine, but things got jammed up when we tried to lower the arm. It turns out that the tension on the tight side of the chain when supporting the arm was so tight that the feed side was completely slack. When we tried to lower, this slack was causing the chain to not feed smoothly onto the small pinion, which was causing the momentary binds-- which could then be cleared by jerking the arm up and then comming back down. Every one in a while you'd hear a loud popping sound, which was the bound chain suddenly settling into the sprocket teeth.
We realised that we had actually managed to flex our intermediate 5/8" axle. After supporting this axle closer to the sprocket, and retensioning the chain, the problem has been removed.
Bear in mind, we're using two fisher price motors, reduced 5:1 _and then_ fed through a dewalt _and then_ reduced by 1:5 _and then_ reduced by 1:6. Thats a much bigger reduction that it sounds like you're dealing with, but we are perfectly happy with the arm speed of our system.
One unrelated thing to check at some point would be taking your dewalt appart and looking at the inside of the aluminum gear case assembly. We were seeing worrysome signs of wear (aluminum shavings) until we added our second reduction.
Unread 20-02-2005, 20:12
occra 23.
AKA: ryo
None #1481
yea i was about to say check if you are binding somewhere. bending a 5/8 axle wow. you should probably check to make sure everything is free.
Unread 20-02-2005, 21:00
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
Leaving the pins in and using #35 chain with somewhat loose joints will be a problem for you. We don't leave the pins in them.
Unread 24-02-2005, 14:05
Derek Bessette's Avatar Unsung FIRST Hero
Derek Bessette Derek Bessette is offline
FRC #4976 (Rebels)
Derek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond reputeDerek Bessette has a reputation beyond repute
We had a very similar problem. We removed the anti-back drive pins and the problem went away. I would say you should do the same.
Derek Bessette
Team 4976 - GDHS Rebels
(Formerly Team 1114 and 3571)
Unread 24-02-2005, 14:11
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
Remove the pins and use counterbalance from latex tubing to keep your arm stationary with a tetra in the horizontal position OR use feedback on the arm to allow the controller hold the arm horizontal.
Joe J.
Team #88, TJ2
**FIRST EMAIL**/Important Fisher-Price motor and gearbox information sanddrag FIRST E-Mail Blast Archive 1 11-02-2005 18:19
Need KOP Gearbox Tom Bottiglieri General Forum 4 01-02-2005 15:35
Looking for KoP Drill motor gearbox parts Max Lobovsky Kit & Additional Hardware 2 09-08-2004 20:06
Reverse Gear FizMan Technical Discussion 12 26-04-2004 01:29
How to design a gearbox? Hinkel Y. Technical Discussion 14 07-04-2004 23:06
