Go to Post 1902...hmmmmm did it go oink oink boom when it blew up? - Rohith Surampudi [more]
View Poll Results: Where are you grabbing the tetras?
Top apex of the tetra (crane, hook) 75 67.57%
Bottom of tetra (forklift) 12 10.81%
Other 24 21.62%
Voters: 111. You may not vote on this poll
Unread 23-02-2005, 10:12
tiffany34990 tiffany34990 is offline
tiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond reputetiffany34990 has a reputation beyond repute
Send a message via AIM to tiffany34990
Re: How are you picking up the tetras?
but how many can pick off the floor, auto loader or dependent on the human station????
we have an arm type thing as seen...
Unread 23-02-2005, 10:16
Mullen's Avatar
Mullen Mullen is offline
FRC #0573 (Mech Warriors)
Mullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of lightMullen is a glorious beacon of light
our team was going to go for the simple hook method, but since we thought of it so quickly, we figured everyone else did too ...which turns out to be true...
so we decided to spice things up. our gripper holds all 3 sides facing you off of the auto loader. first we line up by touching the bottom, then we grasp onto the two sides, this gives us much more control of the tetra so we wont lose it while running around the field and getting hit by other bots.
also, it has a certain coolness effect to it, maybe the movie Tremors will stir up your imagination .. we'll post pics later
2002-2003 : 573 Mech Warriors: Student
2005-2007 : 1504 Desperate Penguins: Mentor
2012 - 2016 : 573 Mech Warriors: Mentor
Unread 23-02-2005, 10:42
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
We can...
Unread 23-02-2005, 11:16
Originally Posted by BurningQuestion
We use a simple hook to grap the tetra by the apex.
(...) The drawback to this type of tetra grabber is that we have less control over the tetra, and it tends to swing around a little bit. We are planning on adding a horizontal beam to the hook that will keep it from sliding down the arm too easily, and to hopefully steady it a bit. Non-actuating hooks work well, but only if you design them right.
The most efficient tetra manipulator we developed in mock-up used a skewer with a cross bar behind and slightly below the arm beam. We also found that the skewer worked better when tilted 5-10 degrees upward. So far, I've seen lots of skewers with crossbars -- some powered at the wrist and some fixed -- but only a couple that include that tilt.
Ironically, our team voted on a different manipulator in part because the fixed skewer was too simple. Some teammates wanted to be able to flip the tetra over and carry it over the body of our 'bot, others thought it the skewer would require too much reduction in the arm lifter, and, more importantly, it would have made the pneumatics team unemployed.
Unread 23-02-2005, 11:20
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
We can also pick it up from anywhere. Our first claw was a simple ball with a shovel at the bottom, but we tried it and it wasn't as easy as we wanted it to be, so we designed a new claw. Here's a pic of it (after we painted it).
Unread 23-02-2005, 12:24
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Originally Posted by DangerDanger!
I'd start by moving my eyebrows and asking it "How are YOU doin?"
Just as shown here: http://www.chiefdelphi.com/forums/pictures.php?s=&action=single&picid=10034&directio n=DESC&sort=date&perrow=4&trows=3&quiet=Verbose
Upside, we don't have to lift our arm high to put one on - Also, tetra is secure onece it is in the position shown.
Downside, we may have to come up with an unusual way to load at the human players station.
Unread 24-02-2005, 19:09
Daniel Brim's Avatar
Daniel Brim Daniel Brim is offline
It's hard hat time here in Boston
AKA: DFB
FRC #0125 (NUTRONS)
Daniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond reputeDaniel Brim has a reputation beyond repute
Send a message via AIM to Daniel Brim
We can as well, although the most efficiant way is the human player. Here's a picture of our claw.
-Daniel
2003 (2002) - 2006 -- Team 294, Beach Cities Robotics
2007 (2006) - Present -- Team 125, NUTRONS
Unread 24-02-2005, 19:44
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
-Daniel
We had this idea too. We figured it'd be quite difficult to line up the grabber in the xy plane to pick up tetras from the floor and to score them, so we ultimately went with something different.
How well does your grabber work in terms of lining itself up right? We had a triangular guide in our mock up to help guide the three fingers into the right places.
Unread 24-02-2005, 20:04
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
We are using a claw, it looks a little different now that we had to lose some weight but the idea is the same. It uses a 6 inch pneumatic cylinder to rotate it up or down to pick up and release the tetra. This makes it easy to pick up a tetra from the ground, manual loading station or the human player.
ID:	3004  Click image for larger version
Name:	The claw II.JPG
Unread 24-02-2005, 20:09
Eric Yahrmatter's Avatar
Eric Yahrmatter Eric Yahrmatter is offline
FRC #0033 (Killer Bees)
Eric Yahrmatter has a spectacular aura aboutEric Yahrmatter has a spectacular aura about
We use two plates: 1 that is stationary and one that moves. The moving one goes inside the tetra and lifts it into the other plate like this:
Buzz X
Unread 24-02-2005, 21:48
AKA: DFB
FRC #0125 (NUTRONS)
We haven't actually tried picking it up from the ground, but theoretically (the p-word that the drivers hate) we can do it. The cone helps to center the tetra, and ultimately, if we can get it over the tetra, we can grab it about nine times out of ten. Again, it's much more efficiant to have our H.P. do it, but s/he needs to be tall (I'm 6 feet tall and I need to lift the tetra over my head to get it where it needs to go)
-Daniel
Unread 24-02-2005, 23:31
Pin Man Pin Man is offline
How you doin'?!
AKA: Dave Kingsley
FRC #0088 (TJ˛)
Pin Man has a spectacular aura aboutPin Man has a spectacular aura aboutPin Man has a spectacular aura about
Send a message via AIM to Pin Man
This year 88 decided to go very simple... Nothing complexed about it... Though for those of you who have seen us you know how slick we can be... Though I must say the coolest thing about our robot is the 4 foot lead screw we have in it... tehehe... can't wait till the competition!
AIM SN: ThursdayCambria
Attending Bridgewater State College
Shirt collection- 25, 47, 69, 140, 173, 191, 213, 303, 365, 461, 836, (2)862, 885, 888, 1027, (2)1073, 1156.
Shirts in the works-
Shirt Wish List- 45, 48, 61, 67, 84, 86, 95, 103, 111, 126, 175, 190, 233, 236, 716, 870, 871, 1114, and any other team basically
Unread 18-03-2005, 20:48
jhnphm jhnphm is offline
jhnphm is an unknown quantity at this point
We grab the tetras on the sides when using the autoloader, or have the human player hang it on two bolts in the arm. We do not have the ability to pick tetras off of the ground, or grab vision tetras, but the lack of those abilities hasn't appeared to be of any handicap.
Unread 18-03-2005, 21:50
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is online now
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
We originally went with a forklift design for our grabber. But when we got to competition, we found it was to hard to line up to the auto loader and it was not compatible with the human player.
So on Thursday of SAC we came up with a pneumatic that pushes out to hook the tetra, then retracts to let the tetra slide off. But the pneumatic shaft got bent. So down goes design numero dos.
Our third (and luckily final) design is a simple hook with rods coming out either side to stabilize the tetra. It works reasonbly well, but it isn't as good as a well thought out grabber would be. Everything turned out ok though, we played defense for our alliance and got to the finals for the first time in our team's ten year history.
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 19-03-2005, 10:03
nightrenegade00's Avatar
nightrenegade00 nightrenegade00 is offline
[Crash]
AKA: Tom
None #0230 (The Gaelhawks)
Team Role: Human Player
nightrenegade00 is on a distinguished road
Send a message via AIM to nightrenegade00
Our robot has the ability to pick up tetras off the ground but we barely use it. For any of you who have seen our robot you'll know that we depend on our human player to load us up with up to 3 tetras and cap like a maniac.
-Crash
::[CRASH]:: Team 230 The Gaelhawks
www.shsrobotics.org
N.E.R.D. #27
2006 Judges Award
2006 6th Place Alliance - Valient Effort 195 and 236
2005 UTC Second Place Finalists - Thanks 20 and 173
AutoDesk Visualization Award
2004 & 2005 UTC Winners
YMTC: Descoring Tetras??? Natchez You Make The Call 16 10-02-2005 13:00
Question: Missing Tetras in Human Loading Zone? tribotec_ca88 Rules/Strategy 7 15-01-2005 15:26
How to Stack Tetras in Inventor petek Inventor 0 13-01-2005 11:47
Just where are vision "bonus" tetras placed? David Brinza Rules/Strategy 17 10-01-2005 20:50
Manipulating tetras from the ground. Petey Rules/Strategy 4 08-01-2005 23:19
