Go to Post When you come down to it, FIRST is about people inspiring other people; STEM and the robots are just the subject matter. - RyanCahoon [more]
Unread 24-02-2005, 20:56
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
pic: 696 Circuit Breakers Complete!
Unread 24-02-2005, 20:57
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
Re: pic: 696 Circuit Breakers Complete!
Can you describe that interesting construction method you use for the arm and tower? Is it sheet riveted to angles to create tube? Why choose this (whatever it is) over stock tube?
Team 1257
Unread 24-02-2005, 21:05
The arm is made from either .040 or .050 aluminum sheet (I forget which but it is incredibly thin) formed into C channels. Two C channels are placed over each other and "buttoned up" with aluminum rivets. Anyhow, it came out incredibly light and very strong. We did this because box tubing that large with that thin of a wall is just not available.
Each "joint" is made from 1/2" aluminum plate, pocketed out to leave only 1/8" of thickness where material is not needed.
Unread 24-02-2005, 23:16
Katy's Avatar
Katy Katy is offline
Quis custodiet ipsos custodes?
Katy has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond reputeKaty has a reputation beyond repute
Send a message via AIM to Katy Send a message via MSN to Katy
what motors do you have in the arm?
Unread 24-02-2005, 23:30
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
The whole robot looks insanely cool. All the gearboxes you showed me look really nice on the robot now. Awesome chasis. I see you also have a mount for the camera. Is your robot able to track a tetra?
Unread 25-02-2005, 00:40
Mike Hendricks Mike Hendricks is offline
misses his IFI control system
FRC #0973 (GRR)
Mike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to allMike Hendricks is a name known to all
Looking good. I love the 6 motor drivetrain.
Are your wheels 1 piece or 2 piece? That conveyor belt stuff works really good also
2004-2010: Founding Member, Technical Mentor - Team 1388, Eagle Robotics
2011: ???
Unread 15-03-2005, 16:48
The "shoulder" or the arm is driven by a Van Door motor and the "elbow" is driven by a globe motor. The Globe motor is concealed inside the box of the arm. Each motor is geared down 20:1 with a worm reduction.
The wheels are one piece machined from solid blanks of 6" diameter 2" thick 6061-T6 aluminum. Next year we may go to a two piece clamping wheel so we don't have to put so many screws in the tread to keep it on.
Unread 16-03-2005, 10:38
george56 george56 is offline
the Beast of 116
AKA: Big G
FRC #0116 (epsilon delta)
george56 has a spectacular aura aboutgeorge56 has a spectacular aura about
Send a message via AIM to george56
Originally Posted by sanddrag
The "shoulder" or the arm is driven by a Van Door motor and the "elbow" is driven by a globe motor. Each motor is geared down 20:1 with a worm reduction.
Now i see what that huge gear was for! thats pretty cool!
pic: 696 Circuit Breakers Teaser #2 sanddrag Robot Showcase 3 11-02-2005 05:30
pic: Team 302's Complete Spirit Collection CD47-Bot Extra Discussion 14 01-04-2004 16:21
pic: TEAM 498, 80, and 696 (FINALISTS) CD47-Bot Extra Discussion 7 18-03-2004 00:56
pic: Team 66 Complete CD47-Bot Extra Discussion 11 27-02-2004 06:53
pic: 696 - The 1st late night CD47-Bot Extra Discussion 22 17-02-2004 06:45
