Go to Post I HAVE IT PROGRAMMED!!!! Ive just been forbidden from testing it... they think ill make the bot explode. >.> - Got_POSTWAFFLE? [more]
Unread 25-02-2005, 14:32
zack b zack b is offline
zack b is an unknown quantity at this point
emtey tanks crashing arm
using the fesco and bosh valve how do we keep are from crashing down when theres no air(the air in the tanks is empty) behind it. its possible with two fesco valves but they stop working when theres less than twenty pounds behind them I'm not sure if this is true with the Bosch valve
I'm looking for suggestions for making a relief type valve so are arm can slowly fall like a feather win theres know air left in the tanks.
i am aslo wondering if anybody knows how to get the piston to stop in one place.
arm design Zippiot Technical Discussion 32 27-01-2005 02:56
2-Segment Arm Control Orborde Programming 1 20-01-2005 01:40
Reflected Inertia? archiver 2001 9 24-06-2002 03:50
Controlling Arm travel - Limit Switch or Mechanical Stop? archiver 2001 8 23-06-2002 23:55
