Go to Post I love it when there is someone that obviously "gets it". - dlavery [more]
Unread 23-02-2005, 11:37
Kingofl337's Avatar
You didn't see anything....
AKA: Adam
FRC #0501 (Power Knights)
Robot Drifts when driving strait.
Now the robot is shipped I'm kind of tinkering with last years robot. This robot has some form of loss in the drive train on the left side and causes it to drift intermittently with the 2005 navigation code when driving strait. The encoders work but they don't seem to be used when driving strait. Anyone have some code I can try to adjust PWM's based on encoder counts?
Unread 23-02-2005, 23:27
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Re: Robot Drifts when driving strait.
Here is something our team was toying with...never got it finished and debugged totally...but if your using encoders this is a start for you.
long drv_left_encoder;
long drv_right_encoder;
long drv_diff_left;
long drv_diff_right;
static int DRV_DEADBAND = 5; //only correct left or right side if encoder difference is greater than deadband
static int DRV_BOOST = 10; //turbo boost if button pressed
int print_counter;
int print_counter_before;
relay1_fwd = 0; //turn off lights, not in automous mode anymore.
camera_find_color( 0 ); //turn off vision system.
 p1_y = (p1_y / 3) + ((127 / 3) * 2); //scale down Y axis
 p1_x = (p1_x / 3) + ((127 / 3) * 2); //scale down X axis
 left_pwm = Limit_Mix(2000 + p1_y - p1_x + 127); //limit pwm
 right_pwm = Limit_Mix(2000 + p1_y + p1_x - 127); //limit pwm
 drv_left_encoder = Get_Left_Encoder_Count(); //get encoder count
 drv_right_encoder = Get_Right_Encoder_Count(); //get encoder count
 drv_diff_left = drv_left_encoder - drv_right_encoder; //subtract left from right because I dunno if ABS is supported in this dumb PIC
 drv_diff_right = drv_right_encoder - drv_left_encoder; //subtract right from left because I dunno if ABS is supported in this dumb PIC
if ((p1_y <= 135) && (p1_y >= 120)) //reset encoder counts
	Set_Left_Encoder_Count(0);
    Set_Right_Encoder_Count(0);
	drv_diff_left = 0;
	drv_diff_right = 0;
#ifdef DEBUG_DRVMAN //uncomment DEBUG_DRVMAN in robot.c to get this to excute.
if (++print_counter_before >= 2)
	print_counter_before = 0;
	printf( "BY=%d BLE=%d BLD=%d BRE=%d BRD=%d BLPWM=%d bRPWM=%d\r",p1_y,(int)(drv_left_encoder),(int)(drv_diff_left),(int)(drv_right_encoder),(int)(drv_diff_right),left_pwm,right_pwm);
#endif
if ((p1_x <= 135) && (p1_x >= 120)) //not turning
	if (p1_y >= 145) //check to see if we are driving straight forward
		if (drv_diff_left >= DRV_DEADBAND) //increase power to the right drive pwm12
			if (drv_diff_left > DRV_DEADBAND)
				right_pwm = right_pwm + 6;
			if (drv_diff_left > DRV_DEADBAND + 10)
				right_pwm = right_pwm + 8;
			if (drv_diff_left > DRV_DEADBAND + 20)
				right_pwm = right_pwm + 10;
		if (drv_diff_right >= DRV_DEADBAND) //increase power to the left drive pwm11
			if (drv_diff_right > DRV_DEADBAND)
				left_pwm = left_pwm + 6;
			if (drv_diff_right > DRV_DEADBAND + 10)
				left_pwm = left_pwm + 8;
			if (drv_diff_right > DRV_DEADBAND + 20)
				left_pwm = left_pwm + 10;
	if (p1_y <= 120) //check to see if we are driving straight backwards
				right_pwm = right_pwm - 3;
				right_pwm = right_pwm - 4;
				right_pwm = right_pwm - 5;
				left_pwm = left_pwm - 3;
				left_pwm = left_pwm - 4;
				left_pwm = left_pwm - 5;
else //if we are turning, then don't try to drive straight
	drv_diff_left = 0;
	drv_diff_right = 0;
if (p1_y >= 130 && p1_sw_trig) //forward boost, will be used later for turbo boost pushing power
	pwm11 = left_pwm + DRV_BOOST;
	pwm12 = right_pwm + DRV_BOOST;
pwm11 = left_pwm;
pwm12 = right_pwm;
if (++print_counter >= 2)
	print_counter = 0;
	printf( "AY=%d ALE=%d ALD=%d ARE=%d ARD=%d ALPWM=%d ARPWM=%d\r",p1_y,(int)(drv_left_encoder),(int)(drv_diff_left),(int)(drv_right_encoder),(int)(drv_diff_right),left_pwm,right_pwm);
#endif
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 23-02-2005, 23:35
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
If last years robot used drill motors, they don't drive with the same force if they are turning in opposite directions, Drive the screw in more power and speed. Last year we mounted the motors so they turned the same direction together for forward or reverse. Yes you can solve this with code. Good luck
Unread 25-02-2005, 14:39
bbene's Avatar
bbene bbene is offline
Team 754 Webmaster
AKA: Ben
FRC #0754 (Frostbyte)
Team Role: Webmaster
bbene is an unknown quantity at this point
Send a message via AIM to bbene Send a message via MSN to bbene Send a message via Yahoo to bbene
We had a similar problem with last year's robot because one motor was on the wrong fuse thus causing the robot to drift.
Ben - Team 754 Webmaster/Former Student/College Mentor
Team Site
Personal Site
Unread 25-02-2005, 19:14
JKnox JKnox is offline
JKnox
#0820 (DeltaTech)
JKnox will become famous soon enough
We've had a similar problem a bunch of times. I usually found it to simply be a lack of lubrication. If the robot's been sitting around for a long period of time the gearboxes may need to be greased. The drifting might be the result of one gearbox needing more lube than the other.
Unread 25-02-2005, 20:46
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
True, but only if their tranmissions use the CIMs, like what Biff said, the Bosch Drill motors from 2004 have a winding bias, which makes them turn faster in one direction. Proper lubrication of the gearboxes may help, but you'll still have a bit of drift.
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 01-03-2005, 17:33
Kingofl337's Avatar
AKA: Adam
I't uses a pair of drive motors. The same as this years robots use. Its just a single motor per wheel instead of 2per.
Unread 09-03-2005, 10:10
The cmd_drive code doesn't attempt to make sure the wheels are turning at the same velocity, just that they turn the same number of ticks. Does the robot straighten up at the end?
If you have different amounts of wheel slip on the two sides counting encoder ticks won't help at all.
Hope you guys did well at BAE.
Winning Robot or Quality Robot? Eric Bareiss General Forum 30 09-02-2006 13:19
Manual placement of tetras Petey Rules/Strategy 7 22-02-2005 18:04
Robot veers left when driving backwards! xxmaddjxx Technical Discussion 3 19-02-2005 04:57
Robot Collaboration Karthik General Forum 153 18-02-2004 03:40
about how Drive Train push the robot... shouldn't the force accelerate the robot? Ken Leung Technical Discussion 12 26-11-2001 09:39
