Go to Post GO OUTSIDE, OR SOMETHING. Go do something other than FIRST for a little while - after all, in January, your life is consumed! - Libby K [more]
Unread 25-02-2005, 22:09
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
MPLAB IDE Problem
I get an error that basically means it isn't finding the default header files(math.h, pwm.h, etc.). How do I change where it is searching during the build process?
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 25-02-2005, 22:14
probizzle's Avatar
probizzle probizzle is offline
AKA: Prabhas Pokharel
#0639 (Code Red)
probizzle will become famous soon enoughprobizzle will become famous soon enough
Send a message via AIM to probizzle
Re: MPLAB IDE Problem
Can you display the exact error? We would be able to assist you better that way.
Code Red Team 639 Winners of the 2005 FingerLakes Regional with 191 and 494.
http://pset.deu83.com << my baby
http://www.setgame.com/set/ << it's mother
Unread 25-02-2005, 22:18
D:\Robot\MyFiles\user_SerialDrv.c:27: unable to locate 'string.h'
D:\Robot\MyFiles\user_SerialDrv.c:28: unable to locate 'usart.h'
D:\Robot\MyFiles\user_SerialDrv.c:29: unable to locate 'string.h'
error 1 spawning D:\Robot\mcc18\bin\cpp18
Unread 25-02-2005, 22:24
Also, do I need to specify the output directory and stuff under Build Option(Green)
Unread 25-02-2005, 22:32
You don't need to specify the output directory. It will default to your project folder.
You need to assign:
Library Path to c:\mcc18\h
Include Path to c:\mcc18\lib
both under Project -> Build Options... -> Project
Unread 25-02-2005, 22:42
I did that, and set the linker to the lnk or whatever. It still isn't finding the headers
Unread 25-02-2005, 22:46
It is Include=h
Library=lib
linker=lkr
Unread 25-02-2005, 22:47
Does the .BIN ever need to get remade for my .c code changes? In other words, is it a contant?
Unread 25-02-2005, 23:28
.BIN only needs to be loaded once. Think of it as a patch to your operating system. It doesn't need to be done everytime you start your computer.
Does your MPLAB options window look exactly like this?
http://www.chiefdelphi.com/forums/at...achmentid=2610
Those includes are located by the correct Include Path. You can double-check you have the correct path by cutting it from the Options window and pasting it into Run from your Start menu.
You could try hitting "Suite Defaults" and enter the paths again.
Unread 25-02-2005, 23:58
A build generates .cof.
I think those are files meant for debug purposes.
I assume I only need to dl .hex files to the bot, which I can do with File-->Export-->xxxx.INHEX32
*Update*
Just looked at posted pic, now it genrates new .coff and .hex and .lst
Really, I guess, the only useful is .hex just to get the bot running.
Unread 26-02-2005, 09:29
The .hex is the only file you're after.
Some of the other files are useful for debugging problems or checking on the amount of memory you are using up on the controller.
You can only download the .hex file to the robot using the separate IFI_Loader program available at http://www.ifirobotics.com/docs/ifi-loader-v1-0-10.zip
MPLAB IDE HELP Idaman323 Programming 2 16-02-2005 18:01
MPLAB IDE 6.60 Error mchan1111 Programming 8 08-11-2004 20:17
MPLAB IDE Project Specs Raven_Writer Programming 18 19-01-2004 15:53
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
