Go to Post John Abele certainly deserves much more recognition than he gets. - Richard Wallace [more]
Unread 14-02-2005, 10:39
Squeje250's Avatar
Squeje250 Squeje250 is offline
BIG RED
AKA: BJ Boville
#1259 (Paradigm Shift)
Squeje250 is on a distinguished road
Send a message via AIM to Squeje250 Send a message via Yahoo to Squeje250
TOPHEAVY!!!!!
just woundering who is top heavy and how isnt, if your are what are you doin to make it stay up, and can it get itself back up. i will tell you a little about our robot to start
We are SLIGHLTY top heavy, we made a box for our battery, air pump, and some other smaller things that we will actually have a piston to push it out the back to give us counterweight, and we also have stablizers coming off the front. so we're good.
what about your team.
Squeje250
Team 1259
Unread 14-02-2005, 10:45
Squeje250's Avatar
BIG RED
AKA: BJ Boville
Re: TOPHEAVY!!!!!
oops must of accidently put it in the wrong place.....
Squeje250,
Team 1259 "Paradigm Shift"
"CHANGING THE MIND OF PEOPLE ARROUND US"
2004 Midwest Regionals - "Highest Rookie seed"
2004 Midwest Regionals - "DaimlerChrysler Team Spirit"
Placed 4th (7-1-0) in 2004 Midwest Regionals
2005 Midwest Regionals - "Imagery Award"
Placed 16th (5-5-0) in 2005 Midwest Regionals
2005 Nationals - placed 5th (6-1-0) in NEWTON
Unread 14-02-2005, 15:17
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Is your robot top heavy?
With two 14 lb transmissions only an inch off the ground I'd say no.
Unread 14-02-2005, 15:59
i_am_Doug i_am_Doug is offline
Currently foraging for food..
AKA: Doug
i_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura abouti_am_Doug has a spectacular aura about
Send a message via AIM to i_am_Doug Send a message via MSN to i_am_Doug Send a message via Yahoo to i_am_Doug
good point there...where useing...dare i say BALL DRIVE!!!1 hehehehe
all thou i shouldnt have sayed that
Unread 14-02-2005, 18:44
tellsomebody's Avatar
tellsomebody tellsomebody is offline
None #0768
tellsomebody can only hope to improve
Send a message via AIM to tellsomebody
Talking Re: Is your robot top heavy?
our robot is good looks like were going to be 10lbs under it goooooooooood
haha
ayumi is the best singer ever
Unread 14-02-2005, 20:28
Alex Minot's Avatar
Alex Minot Alex Minot is offline
FRC #1676 (Pascack Pioneers)
Alex Minot will become famous soon enough
Send a message via AIM to Alex Minot
Our robot is very stable...so far....at least it seems so
Unread 15-02-2005, 01:43
Kelvin Ng Kelvin Ng is offline
None #1558 (ACCIDENT Robotics (Albert Campbell Collegiate Institute stuD)
Kelvin Ng is on a distinguished road
we have trouble just trying to tip our robot over. we have to drive it 7-10 feet per second and force it to a complete stop in about 1 second for the rear wheels to raise maybe 3 or 4 inches off the ground and then returning back.
Unread 19-02-2005, 05:00
Someone Someone is offline
Someone is an unknown quantity at this point
^I was wondering what direction you tried to tip your robot. We decided early on that the problem would be getting hit from the side while you have a tetra raised or if you are topheavy. just my 2 cents make sure you are stable to the sides :-) good luck!
Unread 20-02-2005, 12:47
if you were referring to our robot, we drove the robot full speed forward. regarding top heaviness, i've lifted the entire lifting mechanism (shaft connecting to chassis, gears, arm and gripper), and it can't weigh more than 25 pounds. well for the sides, never looked at that. i doubt that tipping over will be a problem for our robot, but only robots on the opposing alliances! >=D
Unread 20-02-2005, 13:30
Wacko324's Avatar
Wacko324 Wacko324 is offline
AKA: Matt Mericle AKA "Miracle Matt"
#1495 (Avon Grove Robotics)
Team Role: Driver
Wacko324 is on a distinguished road
Send a message via AIM to Wacko324
Suprising even with our arm extended completely up, our robot remains stable. This is mostly due to our battery and transmissions being about 3 inches off the ground.
Unread 20-02-2005, 13:39
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Our Chasis is only 1/2 inch off the ground, mostly of the heavy stuff: battery, compressor, storage tanks, transmission e.t.c is on the chassis. So our robot is very stable.
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 20-02-2005, 13:47
Billfred's Avatar
Billfred Billfred is offline
Yesterday we took our robot over to the drama room (home to high ceilings, dark walls, and, most importantly, CARPET!) to give it a spin.
With all newbie drivers (well, some had driven it earlier, but not like this) and a tetra on the end, we were capping like nobody's business.
And not once did it tip. In fact, the only incapacitating moment was when a low-hanging screw got hooked on the wood platform about an inch off the ground in the room.
Unread 26-02-2005, 00:11
we have tried raising the tetra to full height (high enough to stack the middle goal) and were unsucessful tipping the robot even when we drove it full forward and then slammed it into full reverse.... anyways, if it falls down, we aren't screwed anyway
Unread 26-02-2005, 00:49
DangerDanger!'s Avatar
DangerDanger! DangerDanger! is offline
#0294 (Beach Cities Robotics)
DangerDanger! will become famous soon enoughDangerDanger! will become famous soon enough
Re: TOPHEAVY!!!!!
Squeje250
Team 1259
I want to see your active stablilization! That sounds neat.
We are stable and underweight. Therefore we abandoned our outrigger plans. Our team planned for mounting battery and and compressor to help lower and center our center of gravity.
Unread 26-02-2005, 02:53
"Yes, our robot is top heavy, please come tip us over"
Is that the type of responses you expected?
