Go to Post He is just one of the dozens of evil minions I have molded into my image over the years. Be afraid world, be very afraid. - Andy Grady [more]
Unread 07-02-2005, 18:22
Sachiel7's Avatar
Sachiel7 Sachiel7 is offline
<Yes I managed to flip it
AKA: Shayne Helms
FRC #1132 (RAPTAR Robotics)
Sachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really niceSachiel7 is just really nice
Send a message via AIM to Sachiel7
Center of Gravity
I have a few questions about the center of gravity in Inventor 8. First off, is it supposed to shift, perhaps when a mechanism is driven?
I'm not even sure how accurate it is. It's based on the weight of all the parts, right? How can I check to make sure everything weighs the right amount?
Thanks!
-=Sachiel7=-
There's no such thing as being too simple!
Look for Team #1132, RAPTAR Robotics at the VCU Regional this year!
Unread 07-02-2005, 19:08
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Center of Gravity
"File"--"iProperties"--"Physical"
You can adjust the material in this menu, to get an accurate weight.
You need to do this for every part file in an assembly though.
2001-2004: Team 100
2006-Present: Team 254
Unread 07-02-2005, 19:17
Arefin Bari's Avatar
AKA: Ari
FRC #0108 (SigmaC@T)
I am not sure about Inventor 8 but in Inventor 7, on the left side menu (where they list all the parts) if you right click on the assembly and go to properties, and then click on the tab physical, it shows you weight. Inventor 7 and Inventor 8 shouldnt be THAT different from each other.
-Arefin.
<edit>
I just talked to Cory, and came to a conclusion that you will need to specify on each file the type of material you are using in order to get the right mass from the assembly.
</edit>
Unread 10-02-2005, 11:15
Squirrelrock's Avatar
Squirrelrock Squirrelrock is offline
I may be teh programmer?
AKA: Keegan
FRC #0414
Squirrelrock will become famous soon enoughSquirrelrock will become famous soon enough
Send a message via AIM to Squirrelrock
If yor weights are correct, then if you move a part when center of gravity is on, it should move with the changes. Otherwise, just go to file--properties and click on update in the physical properties tab.
Squirrel
Look what I did to Dave:
Aaacckkk! Guurrkkk! Sssnorrrrkkkkk! Brain ... explode ... will. AAAArrrrggghhh!! Must ... not ... think ... about ... 2007 ... yet. Uuurrgghh!!! Still ... have .... to ... resolve ... how ... to ... pack ... parachutes ... for ... 2006 ... Ooorrrkkggnn!!
Sweet!
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
- Nikola Tesla
Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds.
- Samuel Butler
Unread 26-02-2005, 12:25
rmmlg's Avatar
rmmlg rmmlg is offline
#0900 (Infinity)
rmmlg is on a distinguished road
I've tried it out and gotten moving a part to change the cg. You must go under tools and then go to update mass properties. If the cg marker is gray, then you need to do update mass properties in order to get an accurate position.
I've also had a lot of luck with getting a weight estimate for our bot with it. For our chassis and drive train, Inventor estimated 55 pounds, and it was actually 53 pounds. I had to place in dead weights for things such as compressor and motors since the cad models aren't weight accurate. I presume that the cg is jsut as accurate. Just remember to add in your battery weight and the weight of any tetras, etc that you are picking up.
Ryan
Team 900 (Infinity)
Unread 28-02-2005, 10:03
Greg McCoy's Avatar
Greg McCoy Greg McCoy is offline
boiler up!
FRC #3940 (CyberTooth)
Greg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond reputeGreg McCoy has a reputation beyond repute
Send a message via AIM to Greg McCoy
The center of gravity calculation is not accurate for parts/assemblies which have user-defined mass. It only works for parts which Inventor has calculated the mass from the volume of the object and density of the material.
Unread 28-02-2005, 10:28
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
One work around is to make the part to be the right size and shape, weigh it on an accurate scale, then compute density from the Volume provided. You can then make a new material for that part. I did it for the battery becuase all of the models I could find used the default material. I looked up the volume (file>iproperties>physical>volume) and wieghted the battery. Using my calculator I used d=m/v to find the density. I made a new material (format>material>new) and entered in the density I found (its in g/cm^3). I called it the battery material but kept the coloring that it already had on it.
PM if confused.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 02-03-2005, 00:25
JasJ002's Avatar
JasJ002 JasJ002 is offline
Inventor Freak
AKA: Jay
FRC #0662 (Cybersonics)
JasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the roughJasJ002 is a jewel in the rough
Send a message via AIM to JasJ002
Talking Re: Center of Gravity
Just a little heads up this is a very tedius tool that few teams use, although it would be very impressive to the judges.
Unread 02-03-2005, 11:00
jdiwnab's Avatar
AKA: Bryan Hartley
FRC #0617
Which tool would you be refering to? the center of gravity or the materials?
If you are talking about the material, yes if you wait untill the last. If you tell inventor you are making it out of aluminum when you make it, then it is much less tedious. the most tedious part is when I was applying materials to the KOP gear box. the model looked good, but lacked a lot of material/constraints. When they include the ball bearings and all of them need materials, you will get tired of materials and wonder why you want them . But when you find that you might tip, and you can fix it all before your robot is together, it is very useful.
// random()
Center Goal Hardware coastertux Kit & Additional Hardware 8 14-01-2005 15:59
Pre-Shipping Scrimmage at the North Montco Technical Career Center OZ_341 Off-Season Events 1 05-02-2004 23:59
Blue Man Group FIRST get-together? Gui Cavalcanti Chit-Chat 11 16-09-2003 18:11
Full list of teams & competitions archiver 2001 14 24-06-2002 00:52
KSC Results archiver 2000 2 23-06-2002 22:19
