Go to Post Roses are red/Violets are blue/I'll write a poem/Once build season's over. - Taylor [more]
Unread 11-02-2005, 17:35
Thunderhawk1038 Thunderhawk1038 is offline
Thunderhawk1038 is an unknown quantity at this point
Cool using a ps2 controller
If anyone knows how to hook up a ps2 controller to this years OI please post asap and help us out. any response would be appreciated.
team 1038
Unread 11-02-2005, 17:45
REVving up for a new season
FRC #2848 (All-sparks)
Re: using a ps2 controller
i am not sure about a ps2 controller but i know how to use a psone controller and maybe this will help.
basically the 2 thumb pads are essentially tiny joysticks (each one has 2 100k pots) the best way that i have seen to hook that up to the OI is to take the controller apart and solder new leads to the output of those pots and then solder them to a db connector. since both joysticks given in the kit and the pots in the ps1 controller are the same rating this simple trick works...just make sure you check to make sure that your connectors are going to the right pin-outs of the db connector. there are diagrams of the joysticks available online.
hope this helps
note: this required board level soldering so becareful and take your time if you attempt this.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 12-02-2005, 10:34
Thank you for that, we are going to try and find a PS1 controller to use. If any one else has any information on how to use a PS2 or PS1 Controller, please post . Thank you all for your help.
Team 1038
Unread 12-02-2005, 11:12
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
I haven't done it personally, but it might be an interesting project to decode the signal from the controller with a microcontroller or something so that you don't have to modify it.
I was investigating the use of a game console controller a few weeks ago and came across this one for psx:
http://www.gamesx.com/controldata/psxcont/psxcont.htm
It doesn't seem too hard to do.
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 26-02-2005, 14:56
mv.aboyd mv.aboyd is offline
mv.aboyd is an unknown quantity at this point
i converted 2 ps2 controllers for our joystick and i bouht a broken ps2 and put the OI in it and made it so the ps2 cords plug in to the ps2 ports. This was the funest project i have ever done. I dont advise doing it if you dont know what you are doing. First research eveything and then I will tell you i you still want to know and havent already figured it out.
Unread 26-02-2005, 15:19
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
Would this work?
Unread 26-02-2005, 17:15
no you cant buy an adapter you have to do everthing yourself. so same money and dont buy it. If you really want to conver it you have to take apart the controller and desolder everthing. The analog joysticks operate at 10 ohm so the range is almost imposible to drive with, so you have to put a 37k restior or somthng like that and hook up the the varible petentiometer to the right db15 pins and program the new joystick with a range of ten somthing like this
pmw05 = pmw07 = values[p1_x % 256];
pmw06 = pmw08 = values[p1_y % 256];
int values[256] = {
/* 0 */ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
/* 16 */ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
/* 32 */ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
/* 48 */ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
/* 64 */ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
/* 80 */ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
/* 96 */ 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0, 0,
/* 112 */ 0, 0, 0, 0, 20, 38, 55, 69, 83, 94,104,112,118,123,126,127,
/* 128 */ 128,132,140,152,170,192,221,255,255,255,255,255,25 5,255,255,255,
/* 144 */ 255,255,255,255,255,255,255,255,255,255,255,255,25 5,255,255,255,
/* 160 */ 255,255,255,255,255,255,255,255,255,255,255,255,25 5,255,255,255,
/* 176 */ 255,255,255,255,255,255,255,255,255,255,255,255,25 5,255,255,255,
/* 192 */ 255,255,255,255,255,255,255,255,255,255,255,255,25 5,255,255,255,
/* 208 */ 255,255,255,255,255,255,255,255,255,255,255,255,25 5,255,255,255,
/* 224 */ 255,255,255,255,255,255,255,255,255,255,255,255,25 5,255,255,255,
/* 240 */ 255,255,255,255,255,255,255,255,255,255,255,255,25 5,255,255,255
motA = values[p1_x % 256];
motB = values[pl_y % 256];
This is very very hard
Speed controllers won't communicate w/robot controller steven114 Control System 12 03-02-2005 21:26
Program error after controller reset randomperson Programming 6 04-01-2005 23:31
2003 robot controller & interface LGuY Control System 3 04-04-2004 16:01
Help On Coding 2K1 Controller GregTheGreat Programming 9 05-12-2003 18:35
serious problem found - robot controller resets when jarred! KenWittlief Electrical 23 19-03-2003 13:30
