Go to Post I dont compete to win prizes, I compete to win Pride. - CircularLogic [more]
Unread 26-02-2005, 14:27
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
ERROR
I define like this
void Default_Routine(void)
long reduction;
double para;
long nodecimalpara;
long reduction2;
double para2;
long nodecimalpara2;
and get this:
D:\Robot\MyFiles\user_routines.c:239:Error [1105] symbol 'redeuction' has not been defined
D:\Robot\MyFiles\user_routines.c:246:Warning [2058] call of function without prototype
D:\Robot\MyFiles\user_routines.c:247:Warning [2058] call of function without prototype
D:\Robot\MyFiles\user_routines.c:252:Error [1105] symbol 'redeuction2' has not been defined
D:\Robot\MyFiles\user_routines.c:259:Error [1139] integer types required for bitwise XOR operator
D:\Robot\MyFiles\user_routines.c:260:Warning [2058] call of function without prototype
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 26-02-2005, 14:29
Alex1072 Alex1072 is offline
AKA: Alex
#1072 (Harker Robotics Team)
Alex1072 is an unknown quantity at this point
Send a message via AIM to Alex1072 Send a message via Yahoo to Alex1072
Re: ERROR
There's nothing that I can see in your code that should be causing those errors. It would help if you posted the rest of the function.
EDIT: After looking at it again, it looks like you spelled reduction differently from how you declared it:
The symbol 'redeuction' has not been defined, only 'reduction' has been.
Also, for this error:
the 'a^b' in C/C++/java is not actually a to the power of b. It's the XOR operator.
if you have two binary integers: a = 1011, b= 1101, a^b would be: 0110. XOR compares each binay digit of a with the corresponding digit of b. If the digits are different, a 1 is placed as the corresponding digit of the result, if they are the same, a 0 is placed.
If you need to do something like a^2, you should just do a*a. If you need actual exponentials then you have to use math.h or write your own function. If you use the c math library, pow(a, b) = a to the bth power.
EDIT #2: fixed the name of the power function
Alex
President
Team 1072 Harker Robotics
Unread 26-02-2005, 14:36
Re: ERROR
Ok, I will post my function...but where you see ???? it means the number has been editied out for secrecy purposes. BTW with the spelling fixed I still get :
D:\Robot\MyFiles\user_routines.c:242:Warning [2058] call of function without prototype
D:\Robot\MyFiles\user_routines.c:243:Warning [2058] call of function without prototype
D:\Robot\MyFiles\user_routines.c:255:Warning [2058] call of function without prototype
D:\Robot\MyFiles\user_routines.c:256:Error [1105] symbol 'nodecimalparatwo' has not been defined
D:\Robot\MyFiles\user_routines.c:256:Warning [2058] call of function without prototype
D:\Robot\MyFiles\user_routines.c:256:Error [1101] lvalue required
D:\Robot\MyFiles\user_routines.c:257:Error [1105] symbol 'nodecimalparatwo' has not been defined
#include "ifi_aliases.h"
#include "ifi_default.h"
#include "ifi_utilities.h"
#include "user_routines.h"
#include "printf_lib.h"
#include "user_Serialdrv.h"
#include <math.h>
long reduction, nodecimalpara, reductiontwo, nodecomal, paratwo;
double para, para2;
/*---------- Analog Inputs (Joysticks) to PWM Outputs-----------------------
* This maps the joystick axes to specific PWM outputs.
reduction=p1_y-?;
if (reduction>=0)
else
reduction=reduction*-1;
para=((pow(reduction, ?)/?)+?);
nodecimalpara=ceil(para);
pwm01 = nodecimalpara;
reductiontwo=p2_y-?;
if (reductiontwo<=0)
reductiontwo=reductiontwo*-1;
else
paratwo=((pow(reductiontwo, ?/?)+?);
nodecimalparatwo=ceil(paratwo);
pwm02 = nodecimalparatwo;
Unread 26-02-2005, 14:55
AKA: Alex
Re: ERROR
D:\Robot\MyFiles\user_routines.c:255:Error [1139] integer types required for bitwise XOR operator
If you look at the numbers after the name of the file: 243, 243, 255, 256, etc. The compiler tells you on which line the error is happening. Since I don't know the exact line numbers i'm not sure if this is the actual cause of the errors, but:
nodecimalparatwo is not defined, you should look at the variable declaration at the top of your function and make sure you don't use any variables that you do not declare.
The 'call of function without declaration' errors are happening because of the pow and ceil functions. These functions are provided in math.h, and are the correct names (http://www.opengroup.org/onlinepubs/...sh/math.h.html), but in order to use them you have to let the compiler know that you're going to be using the math.h library. In order to do that you have to put this line at the top of your file next to the other similar ones:
#include <math.h>
This will tell the compiler about all the functions that are in the math.h library so that it knows that they exist. The #include command tells the compiler to process the file "math.h" as if it were pasted into the begining of your file. The math.h file has all the declarations that the default c math library needs in order to work, including declarations of the pow and ceil functions you are trying to use.
Alex
President
Unread 26-02-2005, 15:01
Re: ERROR
Ok, I fixed my definitions, but I am still getting the w/o prototype error. I did put the math.h here: It gives me the errors, then compiles further, but gives me build failed.
* FILE NAME: user_routines.c <FRC VERSION>
* DESCRIPTION:
* This file contains the default mappings of inputs
* (like switches, joysticks, and buttons) to outputs on the RC.
* USAGE:
* You can either modify this file to fit your needs, or remove it from your
* project and replace it with a modified copy.
#include <math.h>
Unread 26-02-2005, 15:14
Re: ERROR
I think my math.h file might be bad. See the attachment with it. It doesn't have anything in it.
Unread 26-02-2005, 15:18
AKA: Alex
Re: ERROR
I've never actually used math.h in MPLAB, so I can't really say much. My math.h file is exactly the same though. For ceiling you could easilly write your own function; power is harder if you want it to support non-integer exponents. Anyone else have any suggestions? Is there a way to use math.h in mplab?
Alex
President
Unread 26-02-2005, 15:19
Re: ERROR
Anyone have a good copy of math.h with all the math functions?
Unread 26-02-2005, 16:23
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: ERROR
math.h is just a header file. header files typically don't contain any code, they just have compiler directives in case that library needs other includes, etc. The actual code will be in a math.c file in a libraries folder or something. I'm afraid I can't tell you for certain because I'm not at a computer with the compiler at the moment. At any rate, either you're missing math.c or it's corrupted, or someone's fiddled with compiler settings and you aren't pointing the compiler to the proper library folder anymore.
EDIT:
From a brief perusal, I note that the include folder should be c:\mcc18\lib
Unread 26-02-2005, 17:08
Re: ERROR
First, if the include isn't set to the /h section, it will error with no adc.h found.
Can anyone explain the procedure for getting ceil() and pow() to work. I don't mind if its a header or a c file or manually program it in.
Unread 26-02-2005, 17:26
Re: ERROR
I have made some progress. I got rid of all the error right down to the last lines:
MPLINK 3.40, Linker
Copyright (c) 2003 Microchip Technology Inc.
Error - could not find definition of symbol 'ceil' in file 'D:\Robot\MyFiles\user_routines.o'.
Errors : 1
All i did was this:
* DESCRIPTION:
* USAGE:
#include <math.h>
extern unsigned char aBreakerWasTripped;
/*** DEFINE USER VARIABLES AND INITIALIZE tHEM HERE ***/
/* EXAMPLES: (see MPLAB C18 User's Guide, p.9 for all types)
unsigned char wheel_revolutions = 0; (can vary from 0 to 255)
unsigned int delay_count = 7; (can vary from 0 to 65,535)
int angle_deviation = 142; (can vary from -32,768 to 32,767)
unsigned long very_big_counter = 0; (can vary from 0 to 4,294,967,295)
double ceil(double x);
double pow(double x, double y);
See two last lines. Am I going down the right path? If so, what is causing the error then?
Unread 26-02-2005, 17:36
Re: ERROR
the new error is because ceil and pow aren't really defined as anything, I'm sure.
and my mistake, it's been a while since I've really programmed. I meant the library path should be set to c:\mcc18\lib and look in that folder and make sure there's a math.c file and it has the proper functions.
AKA: Alex
Re: ERROR
MPLINK 3.40, Linker
Errors : 1
All i did was this:
* DESCRIPTION:
* USAGE:
#include <math.h>
Those two lines that you added are exactly what would have been in math.h. Unfortunatly you also need the actual code of the functions. The way libraries usually work in c is that you have a .h file that tells the compiler all the functions and variables defined in the library, and you have a .o file which contains the compiled code. The way a compiler works is that it takes code and then terns each file into a .o file. The .o file contains "object code". The oject code is an intermediary step between the source code and the actual .hex file. The linker then combines all the .o files into one .hex file. The error that you're getting now is because the compiler does sees all the definitions and compiles the user_routines file assuming that the ceil and pow functions exist. When the linker tries to link the object files though, it doesn't find the actual code for the ceil and pow functions. In order for this to work you have to make it so that MPLAB uses math.o as part of the project and links it in along with your code. Alternativly, you can find the source code to math.o, which would be math.c, and compile it as part of your project. Then the compiler would first compile math.c into a new math.o, and then the linker coud use that to create the .hex file.
Alex
President
Unread 26-02-2005, 17:42
Re: ERROR
What do I need to put in math.c to get my 2 functions to work?
Unread 26-02-2005, 19:31
Re: ERROR
I think I made a tiny bit of progress in finding a math.c Only problem is, I get this error.
Make: The target "D:\Robot\MyFiles\main.o" is up to date.
Make: The target "D:\Robot\MyFiles\user_SerialDrv.o" is up to date.
Make: The target "D:\Robot\MyFiles\user_routines.o" is up to date.
Make: The target "D:\Robot\MyFiles\user_routines_fast.o" is up to date.
Make: The target "D:\Robot\MyFiles\printf_lib.o" is up to date.
Make: The target "D:\Robot\MyFiles\ifi_utilities.o" is up to date.
Make: The target "D:\Robot\MyFiles\ifi_startup.o" is up to date.
Make: The target "D:\Robot\MyFiles\math.o" is out of date.
Executing: "D:\Robot\mcc18\bin\mcc18.exe" -p=18F8520 "math.c" -fo="math.o" /i"D:\Robot\mcc18\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
D:\Robot\MyFiles\math.c:65:Error [1302] old style function declarations not supported
Halting build on first failure as requested.
BUILD FAILED: Sat Feb 26 16:30:19 2005
error with adc.h incognito_NICK Programming 2 05-02-2005 23:27
MPLink Error cloudago Programming 2 01-02-2005 23:00
MPLAB build error cabbagekid2 Programming 7 12-01-2005 13:36
PHP and Wiki Error Venkatesh Website Design/Showcase 2 24-07-2004 15:51
EMERGENCY! EPROM FULL error?!? CHSguard72 Programming 2 05-03-2003 20:51
