Go to Post And I think the poll needs another option: WILL be under weight ... eventually ... just get me a drill. :D - Franchesca [more]
Unread 18-02-2005, 00:29
rcubes85 rcubes85 is offline
no team (TBD)
rcubes85 is on a distinguished road
Send a message via AIM to rcubes85
Lights in Joystick board or control board
Hello again folks our team was thinking of putting some lights in our joystick board is there a rule that say that we cant do that? Or is there a rule that say that say that we have to use the power from the operator interface to power any form of light? Does this make sense?
you can run from the past
you can change the present
but you can't outrun the future
becuase what you do in the presents depicts your future
Unread 18-02-2005, 00:31
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: Lights in Joystick board or control board
Well, that is legal for the first part to put lights on the joystick board. But what you have to do is get a seperate battery to power the lights.
Unread 18-02-2005, 00:33
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
If you look in the OI reference guide, there are four pins on two of the ports that provide 5V at 10mA specifically for powering LEDs. You can use those, if you wish. Otherwise, they have to be powered by a battery.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 18-02-2005, 02:37
no team (TBD)
Thank you guys for all your help.
Unread 18-02-2005, 13:09
evilhunter evilhunter is offline
evilhunter is an unknown quantity at this point
HI we are a rookie team from Onekama Mi we are basically in the middle of no where. I do have a question about the switches on the OI custom board. Ok i understand that we cannot use lighted switches. But can we still use the switch and not wire the light in. Ok one more question can I use analog varible names to use on a switch like on p4_x or something to make it fire a button or not.
thanks for the help in advance
Unread 18-02-2005, 14:37
jgannon's Avatar
I ᐸ3 Robots
AKA: Joey Gannon
Yes. Just be absolutely sure that the light isn't connected, or you'll fry the OI.
Yes. The switch states are stored to p4_sw_trig, p4_sw_top, p4_sw_aux1, and p4_sw_aux2.
_
Unread 26-02-2005, 02:42
mv.aboyd mv.aboyd is offline
mv.aboyd is an unknown quantity at this point
Hi I am a rookie and i got the task of making a control board and I moded 2 ps2 controllers to control our robot and it works, but i just need to know if the OI has to be visible because it is curently in a ps2 case.
Unread 26-02-2005, 11:21
Billfred's Avatar
Billfred Billfred is offline
Yes, the OI (specifically the lights) have to be visible.
Unread 26-02-2005, 14:51
what lights have to be visible, because can i just use the 8 led ports and put the leds on top of the ps2
Unread 26-02-2005, 15:08
oh yea and are we allowed to have a battery power out OI
Unread 26-02-2005, 15:10
Specialagentjim's Avatar
Specialagentjim Specialagentjim is offline
"I am a Meat Popsicle"
AKA: Jim Martz
None #0108 (SigmaC@T)
Specialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to beholdSpecialagentjim is a splendid one to behold
Send a message via AIM to Specialagentjim
Also, the OI has to be accessible, as the competition port must be plugged in directly to the FIRST field.
Curie Division 2005 Champions (175, 33, 108)
UCF 2005 Website Award
Midwest 2005 Delphi's Driving Tomorrow's Technology
2004 UCF QuarterFinalists (1065, 86, 108)
UCF 2003 Regional Champs/Entrepreneurship Award
Midwest Regional 2003 Leadership In Controls/Website award
Nationals 2003 Quarter Finalists
Robot Rodeo 2003 Champions (Alliance: 180 and 186)
AIM S/N: Specialagentjim
Unread 26-02-2005, 15:13
I know that I out the competition port where the expansion bay was
Unread 26-02-2005, 15:46
Billfred's Avatar
Essentially, all of the LEDs have to be visible. It helps immensely when your robot is going haywire, and you need to know what's up.
As for the battery connection, I'm not quite sure what you mean--but anything that connects to the joystick ports on the OI has to run off OI power. If you were to connect something to the Dashboard port (laptop, PDA, etc.), then you can run that off batteries. You can also power any lights or miscellaneous bling on your board from batteries--but they can not connect to the OI.
Unread 26-02-2005, 17:06
thanks i was hoping i wouldn't have to cut a whole in the ps2, but i guess i will.. the battery was to power the OI when it isn't pluged into the wall so it would be cordless..I already did it and it works fine i just need to know if it is allowed
Unread 26-02-2005, 17:34
Billfred's Avatar
Allowed? I dunno--but it is unnecessary at an FRC event.
When you get to the field, your OI will get power from the Competition port. After the match, and while practicing, you'll be on tether (which means your OI will get power from the robot).
Lights on the Control Panel Han Tzu Electrical 5 08-02-2005 13:30
frying control board Denman Technical Discussion 7 07-07-2004 19:11
One Joystick Control KWalsh Programming 4 24-02-2004 17:53
how do i control a piston with a joystick Ryan Foley Programming 2 27-05-2003 17:13
Does anyone have an idea on how to make a joystick program for an operating board? necroprime Programming 8 09-11-2002 19:04
