Go to Post Wait...you're supposed to have a driver? I guess I should have read past the Autonomous section in the manual :D - ASD20 [more]
Unread 26-02-2005, 18:19
syntaxers's Avatar
syntaxers syntaxers is offline
3dsmax Master
AKA: Chi Feng
#0830 (Rat Pack)
Team Role: Webmaster
syntaxers is an unknown quantity at this point
Send a message via AIM to syntaxers Send a message via MSN to syntaxers Send a message via Yahoo to syntaxers
Re: creating environments
another way, If you are lazy to use outside applications, is to create a really dense plane. (like 200 length and width subdivisions) then right click the plane and convert to editable mesh. Enable soft selection and pick a few random vertices and move them up or down. Keep on doing this and you will end up with some funky terrain. Since soft selection is mathmatically based and does not look very "realistic" you can then add a noise modifier and select fractal and set the Z-power to make the terrain "rough"
- Chi Feng - Team 830 Forums
CMUcam II and competition lighting environments dlavery Programming 5 16-02-2005 02:07
creating an array of images, help!! kris_krantz IT / Communications 3 04-01-2005 17:12
Creating Videos Raven_Writer IT / Communications 13 20-06-2004 23:48
Creating a dashboard program Jeff_Rice Programming 18 04-05-2003 23:21
What about creating a real life series about FIRST? archiver 2001 6 24-06-2002 03:46
