Go to Post Who knew a single variable could be so deadly? - 3DWolf [more]
Unread 26-02-2005, 15:43
stinger's Avatar
stinger stinger is offline
The laziest animator ever!!!!
AKA: wouldn't you like to know;)
Team Role: Animator
stinger is an unknown quantity at this point
Question creating environments
Im having a little trouble, i need to know how to elevate areas to make small hills or mountains in 3ds max. also i need to know how to animate water to make waves.
There is a method to my madness..I just don't know what it is...then again if I did know then I wouldn't be mad now would I?!?!
Avatar by VG Cats
Last edited by stinger : 26-02-2005 at 15:56. Reason: forgot to mention its for 3ds max
Unread 26-02-2005, 16:10
rowe rowe is offline
Eric Rowe
FRC #1097 (Site 3 Engineering)
rowe has a spectacular aura aboutrowe has a spectacular aura about
Send a message via AIM to rowe Send a message via MSN to rowe Send a message via Yahoo to rowe
Re: creating environments
I definately know an easy way to make hills (I used this method for my 2005 animation).
  • You're going to want to start with a plane making sure to bump up the segments.
  • Next make a picture from black to white. I did this in Photoshop, but other programs will work as well. Just use a brush tool, turn down the opacity and soften the edges, then brush randomly, keeping in mind that the blackest areas are the lowest, and the whitest are the highest.
  • Next, in 3dsmax, apply a Vol. Select Modifier to your plane. Change these settings: Stack Selection Level = Vertex, and Select By = Texture Map -> Bitmap -> the picture you just made.
  • Apply a Displacement Modifier to your plane and bump up the displacement amount until it looks the way you like it.
I've attached a zip with both the .max file and the .jpg I'm using for the map.
Eric Rowe | Alumn
Team 1097 | Site 3 Engineering
2005 Silicon Valley Regional Finalists
2005 Silicon Valley Regional Sportsmanship Award
2005 Sacramento Regional Finalists
2005 Sacramento Regional Sportsmanship Award
2004 Silicon Valley Regional Sportsmanship Award
2004 Sacramento Regional Visualization Award
2004 Sacramento Regional Engineering Inspiration Award
Unread 26-02-2005, 18:19
syntaxers's Avatar
syntaxers syntaxers is offline
3dsmax Master
AKA: Chi Feng
#0830 (Rat Pack)
Team Role: Webmaster
syntaxers is an unknown quantity at this point
Send a message via AIM to syntaxers Send a message via MSN to syntaxers Send a message via Yahoo to syntaxers
another way, If you are lazy to use outside applications, is to create a really dense plane. (like 200 length and width subdivisions) then right click the plane and convert to editable mesh. Enable soft selection and pick a few random vertices and move them up or down. Keep on doing this and you will end up with some funky terrain. Since soft selection is mathmatically based and does not look very "realistic" you can then add a noise modifier and select fractal and set the Z-power to make the terrain "rough"
- Chi Feng - Team 830 Forums
Unread 26-02-2005, 18:46
kcy88's Avatar
kcy88 kcy88 is offline
Animator
AKA: Kevin
FRC #0075 (Roboraiders)
kcy88 is a jewel in the roughkcy88 is a jewel in the roughkcy88 is a jewel in the rough
Send a message via ICQ to kcy88 Send a message via AIM to kcy88
water & waves:
-create a plane, doesn't matter what size, set the multiplier to a higher value(ex.10)
-add a wave modifier, adjust the settings, animate the settings
-add another wave modifier for different wave patterns, rotate the gizmo, animate the settings
Team 75 - Roboraiders
Hillsborough High School Robotics
2006 Boston Regional Autodesk Visualization Award
2006 Boston Regional Engineering Inspiration Award
2006 New Jersey Regional Engineering Inspiration Award
2005 New Jersey Regional Autodesk Visualization Award
2005 Duel on the Delware champions
2005 Brunswick Eruption 4 champions
Unread 26-02-2005, 20:38
CADman CADman is offline
Dan Ward
#0045 (TechnoKats)
CADman is an unknown quantity at this point
Stinger,
Use a quad patch. Modify and scroll all of the way down to the bottom of the modify menu. A new feature that allows you to "paint" hills and valleys awaits. It is so easy to use, I will leave it up to you to explore. Check out how we used it in our animation this year.
http://www.technokats.org/2005animation.htm
This method is not he best way to simulate water. A quad patch with a Noise modifier will work great. The noise can be animated and does a pretty good job as water.
Post again if you need more info.
CADman
Unread 26-02-2005, 22:19
Eric Rowe
Originally Posted by CADman
Stinger,
I didn't about that, your way does sound easier. Maybe I'll have to check that out when I'm not too busy.
Eric Rowe | Alumn
CMUcam II and competition lighting environments dlavery Programming 5 16-02-2005 02:07
creating an array of images, help!! kris_krantz IT / Communications 3 04-01-2005 17:12
Creating Videos Raven_Writer IT / Communications 13 20-06-2004 23:48
Creating a dashboard program Jeff_Rice Programming 18 04-05-2003 23:21
What about creating a real life series about FIRST? archiver 2001 6 24-06-2002 03:46
