Go to Post Robotics. Seems to be the answer to a lot of things I don't do. - Keith Chester [more]
Unread 26-02-2005, 23:23
Gary Bonner Gary Bonner is offline
FRC #3974
Gary Bonner has a spectacular aura aboutGary Bonner has a spectacular aura about
Which is faster?
if p1_y > 125
	Pwm1_green = 1;
else
	Pwm1_green = 0;
or
Pwm1_green = p1_y / 126;
Unread 26-02-2005, 23:25
Alex1072 Alex1072 is offline
AKA: Alex
#1072 (Harker Robotics Team)
Alex1072 is an unknown quantity at this point
Send a message via AIM to Alex1072 Send a message via Yahoo to Alex1072
Re: Which is faster?
Originally Posted by Gary Bonner
if p1_y > 125
	Pwm1_green = 1;
else
	Pwm1_green = 0;
or
I would say #2, but i'm not an expert on optimization.
Alex
President
Team 1072 Harker Robotics
Unread 26-02-2005, 23:56
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I think it depends on the processor. Fancy pipelined processors don't do well with branches and if statements. I'm pretty sure the PIC isn't that fancy. The only real question is if it can complete a divide in one clock cycle or not. I'd bet on the latter being faster, though. The branch instruction is more likely to delay the processor more than a simple integer divide. Either one is going to be pretty darned fast, though.
Unread 27-02-2005, 00:14
Arrow250 Arrow250 is offline
Custom User Title.
AKA: Nate
#0250 (Dynamos)
Arrow250 is an unknown quantity at this point
Well it will be different on every CPU, but to give you an idea, on x86 machines, it compiles down to 27 and 31 lines of ASM for #1 and #2 respectively. So basically, the first has few instructions at a lower level. Though that still may not give much indication as to how fast it will run on the IFI PIC's. Especially with all the variables and aliases involved in the operation.
Unread 27-02-2005, 00:51
Nate, x86 has a built in divide instruction, while the PIC does not, so I'd expect both to be similar in number of instructions on x86 but not on the PIC. You didn't say how long each took though, because the divide instruction will take several cycles to execute.
Gary, You can put both in your code and compare them in the list file. That will give you the exact answer for the PIC.
Also, is it absolutely necessary to divide by 126? It would be much faster to divide by 128, which boils down to a rotate and an AND.
coupling Bosch & Atwood motors caffel Motors 10 28-05-2003 16:00
How Do I Program My RC To Spot One wheel From Going faster than the other Kyle1010 Programming 5 12-01-2003 15:30
Robot Speeds - Opinions sought archiver 2000 31 23-06-2002 23:04
