Go to Post I sincerely hope no one on CD is going to neg rep you for thinking - Richard Wallace [more]
Unread 26-02-2005, 23:40
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Where to purchase internal gears?
Where can you purchase internal gears? I'm looking for either 32 or 24 DP in steel with a face width of preferable more than 1/4" Does such a thing exist or does it have to be custom made? I have already checked Boston, Berg, SDP, and McMaster, none of which have what I am looking for.
Unread 27-02-2005, 00:47
dlavery's Avatar
dlavery dlavery is offline
Curmudgeon
FRC #0116 (Epsilon Delta)
Re: Where to purchase internal gears?
How many teeth? Pressure angle?
Stock Drive Products carries some internal gears. Go to their on-line store and search on "internal."
Rush Gears will custom make them for you, but you will pay through the nose for them.
Are you sure you need them in steel? Boston Gear makes 24DP and 32DP internal gears, 1/4" face width, in brass, with both 14-1/2 and 20 degree pressure angles.
Arrow Gear makes a large assortment of internal gears, up to 17" pitch diameter.
You can also find several more gear manufacturers at powertransmission.com.
-dave
Unread 27-02-2005, 01:58
I'm not exactly sure of what I want, I was just trying to get an idea of what is available. So, let me ask a few questions.
Can brass be hardened? Also, can two gears accurately be "stacked" to essentially become one wider gear? If so, how?
Last, are there any off the shelf planetaries besides "speed reducers" and drill gearboxes (and AndyMark ones)?
Unread 27-02-2005, 05:22
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
I'll bet one of our sponsors Al-Craft Industries Inc., can laser cut a couple of them for you. I'll be the go between of you promise to send them a thank you e-mail.
Send me a DXF line drawing of the gear & let me know the thickness & type of material. I have aluminum, mild steel, high hard armor, & titanium - but the choice will depend on the thickness you need. OTOH, maybe we can lathe them down to the thickness?
This message is hidden because Jack Jones is on your ignore list.
request for info on gearbox gears jskene Technical Discussion 0 08-01-2005 18:07
Looking for gears from BostonGear in Inventor.. geo Inventor 6 05-08-2004 10:07
Looking for KOP Helical Gears ChuckDickerson Kit & Additional Hardware 1 21-07-2004 15:39
Gears in Inventor Joshua May Inventor 12 01-07-2004 23:32
What type of steel are gears commonly made from? Matt Adams Technical Discussion 5 02-01-2004 23:19
