Go to Post Success is the gleam in a child's eyes when they catch their first glimpse of your creation and their life is forever changed. - SlamminSammy [more]
Unread 26-02-2005, 13:44
IA-Howitzer's Avatar
IA-Howitzer IA-Howitzer is offline
Theiss
AKA: Andrew Theiss
FRC #0100 (Woodside High Robotics)
IA-Howitzer is on a distinguished road
Send a message via AIM to IA-Howitzer
What Motors/Drivetrains are YOU using?
I just wanted to find out what kind of motors and drivetrains other teams have. Maybe you can even share your secret plan, like we (Team 100) has a secret motor design show in the picture attached (introducing the new Hemi V8 pneumatic powered engine... MUAHAHHAHA). No, but really we have a swirve drive with 2 powered wheels in the center of the robot and 4 omni wheels on the corners. How bout the rest of you?
Unread 26-02-2005, 14:36
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: What Motors/Drivetrains are YOU using?
Oh ya we were also thinking somewhere along the line of an Aston Martin D12 Vanquish S engine . 6 speed. 0-62 in only 4.8 sec. Top speed more than 200 mph...It's shweeeet .
Actually We used the gearbox in the KOP and have 4WD with 2 onmis in the front to help with turning.
Unread 26-02-2005, 14:44
Stephen.Yanczura's Avatar
Stephen.Yanczura Stephen.Yanczura is offline
opportunist
FRC #0195 (Cyberknights)
Stephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to allStephen.Yanczura is a name known to all
Killer bee's (T33) style four speed automatic with a custom designed motor combiner integrated into the gearbox. Each gearbox is powered by two CIM motors and power is delivered to the ground by a ~30" tank track Assembly. The robot contains two gearboxes modules and two track modules. Each piece of our drive train is held in with four 1/4-20 bolts and the entire drive train can be removed in about 2 minutes (two people working).
Unread 26-02-2005, 14:45
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
You guys will never make the weight limit, this is the way to do it.
The horsepower is a little light so we might up it to something like this:
But seriously, we are using our brand new HexaMax R2 six motor two speed drive system.
Unread 26-02-2005, 14:51
FusionDude364's Avatar
FusionDude364 FusionDude364 is offline
Official Team Fusion Robot Pimper
AKA: Daniel Odom
FRC #0364 (Team Fusion)
FusionDude364 is an unknown quantity at this point
We have a six wheel drive, two speed transmission drivetrain that is powered by two CIM motors on each side (4 in all). It also has zero-turn capability.
Team #364 (Team Fusion) Alumni
Proud MS State Bulldog and AFROTC Cadet
Unread 26-02-2005, 14:52
Max Lobovsky's Avatar
Fold em oval!
FRC #1257 (Parallel Universe)
What is that second pic, Sanddrag? Some sort of power plant?
Team 1257
Unread 26-02-2005, 16:59
FRC #0701 (RoboVikes)
lol is that like the engine for the titanic or something... !
we use KOP tranny w/ a 6 wheel drive center wheel offset for fast turning
Team 701
Unread 26-02-2005, 17:36
That's the second biggest diesel engine I've ever seen... Of course, the 14-cylinder version is even -- you know -- bigger: Big Diesel
From the Website:
"The Wartsila-Sulzer RTA96-C turbocharged two-stroke diesel engine is the most powerful and most efficient prime-mover in the world today. (...) These engines were designed primarily for very large container ships. (...) The cylinder bore is just under 38" and the stroke is just over 98". Each cylinder displaces 111,143 cubic inches (1820 liters) and produces 7780 horsepower. Total displacement comes out to 1,556,002 cubic inches (25,480 liters) for the fourteen cylinder version. (...) Even at its most efficient power setting, the big 14 consumes 1,660 gallons of heavy fuel oil per hour."
More power.
Unread 26-02-2005, 22:43
occra 23.
AKA: ryo
None #1481
so it doesnt turn? so is this thread serious or funny? cant tell
Unread 26-02-2005, 22:51
AKA: Daniel Odom
Sorry I guess that was a little confusing lol. I mean it can turn in place. Very rapidly I might add. If you want to watch a video of what I mean click here. Click on the week 3 test drive clip.
Unread 26-02-2005, 23:16
Theiss
AKA: Andrew Theiss
This thread is a little serious and a little funny, so i would consider it both. By the way, very nice pic of the engine the size of a blimp. That had me laughing for a while. (If you made it under the weight limit with that thing, no1 would stand a chance).
Unread 27-02-2005, 00:01
bombadier337's Avatar
bombadier337 bombadier337 is offline
1337 U53R
AKA: Shaver
None #1541 (MidloCANics)
bombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nicebombadier337 is just really nice
Send a message via AIM to bombadier337
I'm gonna say, hooray for the gearbox included with the kit! It's what we used.
Midlothian High School - Team 1541
2005 Radioshack Innovation in Control - NASA/VCU Regional
2005 Rookie Inspiration - NASA/VCU Regional
Unread 27-02-2005, 00:04
Is the end section of your arm made out carbon fiber and fiberglass??? Nice 'bot, by the way.
Unread 27-02-2005, 13:54
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
We turned the kit gearbox into a two speed with two CIMs.
http://www.chiefdelphi.com/forums/sh...ad.php?t=35386
Unread 27-02-2005, 14:06
Billfred's Avatar
Billfred Billfred is offline
That's spiff.
Our robot is using one CIM per side, two-wheel drive, kit transmissions.
And now that I think of it...
Ockham's Raizor (2005) vs. Bob (2004)
Motors (drive): 2 CIMs vs. 2 window motors
Motors (other): Van door vs. Van door
What did the other motor do: Winch vs. Winch
The backside: Casters vs. Casters
So I guess Karthik's notion that the 2005 robots would just be an evolution of the 2004 robots is about right. This year, we just happened to perfect the three-motor-with-a-winch-and-casters concept.
2 Globe Motors??? ChuckDickerson Motors 18 25-01-2005 15:53
Drill Motors Removed? Illegal this year? Chris_Elston Motors 12 12-01-2005 09:04
