How to calculate planetary gear ratios?
At one time or another I knew how to do this but it has been a while.
What is the formula for a planeatary gear ratio involving the tooth counts on sun, planet, and ring gears assuming the ring gear is held stationary? Thanks. EDIT: I looked a little harder and found it to be (sun+ring)/(sun). ![]() Last edited by sanddrag : 27-02-2005 at 03:26. |
Re: How to calculate planetary gear ratios?
While this was mentioned, does anyone know any good websites that tell you how to do this?
This is one thing I would like to know how to do! I could probably google it, but there are probably a million websites that are not what I need. |
Have you had a chance to read the white paper by Paul Copioli, here, it covers very well planetary systems and of course dual motor planetaries also. There's also a good pdf written by Martin L. Culpepper, here which helps a lot. Good luck
| Efficent number of Gear ratios... | Matt Attallah | Kit & Additional Hardware | 12 | 14-09-2004 10:42 |
| gear ratios | roboteer49 | Motors | 22 | 29-04-2004 20:51 |
| Reverse Gear | FizMan | Technical Discussion | 12 | 26-04-2004 01:29 |
| Thunder Chicken CCT | Simon G | Motors | 4 | 03-01-2003 13:18 |
| Drill motor gearBox question | Dennis Hughes | Motors | 4 | 11-10-2001 07:11 |
