Change from External to Internal teeth
If I have a drawing of a tooth profile (accurate, involute) in AutoCAD of an external spur gear, is there any way to make this the profile for an internal gear? I don't know anything about AutoCAD but theoretically If you "flipped" it using the pitch diameter as a "curved axis" upon which to "flip" would that work? If so, how do I actually do that in AutoCAD? Thanks.
EDIT: I was just looking at some pictures of internal gears, and now I'm wondering, is it the exact same profile with no flipping? Like a "negative" in a sense. Like if I took a spur gear and put in in a bucket of plaster, and then it hardened and I pulled it out, would I have an internal gear of correct dimension/shape? Last edited by sanddrag : 27-02-2005 at 03:24. |
Re: Change from External to Internal teeth
No - you would not end up with a gear of the proper tooth shape, pitch diameter, nor clearance.
You'd be better off using a single tooth in the proper orentation, translating it to where it's pitch line meets the pitch crcle of the mating gear(s), then rotating instances by the proper amount - I.E. 360/(number of teeth) |
Sorry about the double post, I was going to delete one but it was late last night and I forgot. Anyhow, now that I know they are not the same, is there any way I can derive the correct internal profile from the external profile I have? I can't draw a proper single tooth. See, I need the drawing to be involute so I can take this drawing somewhere to be manufactured (edm, perhaps laser, etc.). I have a program (Geargen) that will make an involute external gear in a dxf, but not internal. Can I somehow convert it in Inventor or AutoCAD? Or are there any other programs that will make the drawing?
I found an involute internal gear on cbliss, but it does not seem to show anything when I open it. All the features are grey-ed out. Is there any way to make a gear drawing good enough to cut in AutoCAD? |
www.bostongear.com has CAD files for all the gears they sell which includes internal gears as big as 16 pitch. Click on Boost Spec 2 on their website (you will need to register).
comes with a 15 day trial, after that 69.95 it does internal, external, sprockets, racks, and right angle. Very easy to use Good luck |
If you use a decent involute profile in Inventor, you should be able to export a dxf from a .idw of it to AutoCAD or a CNC program to cut. |
#7
I still use a lisp file that I found many years ago for AutoCAD. Do a search for Gear.lsp on the Net and you should find what you need. I have modified mine over the years, and it works great. I send the data to MasterCAM or Gibbs and they cut well on our Fadal machine.
#11
-dave |
| Team Plan change due to Fee increase? | SpaceOsc | Team Organization | 3 | 02-06-2004 21:29 |
| heres the code. y this not working | omega | Programming | 16 | 31-03-2004 15:18 |
| Extras, External Spotlights, etc | Brandon Martus | CD Forum Support | 12 | 01-01-2004 23:55 |
| How many posters does it take to change a lightbulb? | Brandon Martus | Chit-Chat | 7 | 22-02-2002 19:48 |
