Go to Post Welcome to ChiefDelphi.com. Get ready for the craziness. - Andy Baker [more]
Unread 26-02-2005, 20:38
Best Available Data
FRC #1778 (Chill Out!)
pic: 1276 - Kaizen Blitz 2005 bot
Unread 26-02-2005, 20:41
dlopez dlopez is offline
FRC #0191 (X-Cats)
Team Role: Driver
dlopez is on a distinguished road
Send a message via AIM to dlopez
Re: pic: 1276 - Kaizen Blitz 2005 bot
That claw definitely resembles our claw this year and we love ours so far
Unread 26-02-2005, 22:26
chantilly_team chantilly_team is offline
chantilly_team is an unknown quantity at this point
How do you manage your center of gravity? What if some bot hits you?
Unread 27-02-2005, 01:24
Scythe's Avatar
Scythe Scythe is offline
That guy with the cape...
AKA: Scott
FRC #0180 (S.P.A.M.)
Scythe is an unknown quantity at this point
Send a message via AIM to Scythe
I'm just going to assume that you can hold the tetra better than the arcade version?
Unread 27-02-2005, 15:52
Best Available Data
Yes. The pneumatic cylinder keeps it closed. You can't pull it out of the claw actually.
Most of the time tetras are contained on the base. Also when there are tetras in the air there are usually one or two or three 8 lb tetras on the base. They are only in the air near the goal. Also in case anyone wanted to do some scouting heres the full spec sheet:
2 front omni wheels and 2 back 8" back wheels (not omni wheels)
Max speed 9fps
Able to place the 7th tetra on the center goal.
Can carry 2 tetras in the claw and a stack of 4 on the base
Can load 4 tetras from the manual and deploy them on a nearby goal in 45 secs.
Autonomous Mode-Able to stack the tetra given to each alliance at the beginning of the match.
Unread 27-02-2005, 18:48
geeknerd99's Avatar
geeknerd99 geeknerd99 is offline
Fire Hazard
AKA: Daniel Lin
FRC #0401 (Hokie Guard)
geeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud ofgeeknerd99 has much to be proud of
Send a message via AIM to geeknerd99 Send a message via MSN to geeknerd99 Send a message via Yahoo to geeknerd99
And the mentors said it couldn't be done! That's exactly the type of claw I came up with at the beginning of the season! Rrrggghhh....
Oh well... at least we saved some weight by not having pneumatics...
pic: 2005 Team 1549 Rookie Pic Eupher Robot Showcase 7 01-03-2005 11:20
pic: S.P.A.M. 2005 Bot tiffany34990 Robot Showcase 26 26-02-2005 20:34
pic: Team 107 Bot Pic 01 brent_107 Robot Showcase 13 26-02-2005 14:49
Team 95 Bot pic, this thing is crazy! JamesCH95 Robot Showcase 0 22-02-2005 13:53
2005 Beantown Blitz! Erin Rapacki Off-Season Events 1 01-11-2004 08:35
