Go to Post we learned that's what happens when you start building without even thinking about weight. next year, we'll lighten everything BEFORE we mount it. - greencactus3 [more]
Unread 28-02-2005, 16:08
Inert Entry Inert Entry is offline
Inert Entry is an unknown quantity at this point
Cool Flow Switch question?
I am looking for a flow switch.
Must be able to operate at >125psi air at max flow >200 lpm.
Must be able to cycle 15-35 times a minute continuous use.
Must be small <2" dia <3" long.
Must be able to operate in any orientation.
Must have SPDT switching at 12vdc.
Would like a fail open.
I have looked at a Malema flow sensor that uses a magnetic read switch.
This is just the type of thing any ideas?
Thanks
Inert Entry
Unread 28-02-2005, 16:22
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Flow Switch question?
This isn't a general engineering forum. This is a forum intended to support teams competing in the FIRST competition. We don't work with flow rates and pressures near what you're talking about, so you're less likely to find specific reccomendations, however there are a lot of experienced engineers around. You might find a good stepping stone to what you're looking for. That said, the best I can offer is a link to GlobalSpec
There you can find a list of pnematic valve suppliers, and if you register with them, you can filter the catalogs of some suppliers according to your needs.
EDIT: Come to think of it, you'd probably be best served by just calling SMC America at 1.800.SMC.SMC1
PRESSURE SWITCH Mr. Steve Pneumatics 20 01-12-2005 10:20
LEDs in switch box. ZZII 527 Electrical 5 06-03-2004 19:39
Digital Inputs interfering with each other Bongle Programming 8 23-02-2004 11:18
Need help with 255 Variable Joseph F Programming 18 26-02-2002 14:49
how do u hook up things through the fuse panel? chrisw Technical Discussion 9 12-01-2002 19:51
