Go to Post Will.I.Am is not FIRST. - BrendanB [more]
Unread 26-02-2005, 21:11
ace123's Avatar
ace123 ace123 is offline
AKA: Patrick Horn
FRC #0008 (Paly Robotics - http://robotics.paly.net/)
ace123 has a spectacular aura aboutace123 has a spectacular aura about
Send a message via AIM to ace123
Re: ERROR
First of all, I would HIGHLY recommend writing and using your own functions.
Are you using floating point powers (6^2.5) or only integers(6^3).
If you are using integer powers then it would be very easy to write your own function:
long powl(long y, int x) {
    long result=1;
    int i;
    for (i=0;i<x;++i) {
        result*=y;
    return result;
(make sure to call a different name like powl instead of pow to avoid conflicts.)
That is much faster and better than using a function with floating point numbers (doubles), which are bad to use on these microprocessors and which one has little reason to use.
Now, to answer your question about the hard way to do this:
The "old style" functions are when you do:
double pow(y,x)
double y, x;
The way to fix it is to change math.c:
double pow(double y,double x)
Do the same thing with ceil at line 71:
double ceil(double x)
-Patrick Horn, Paly Robotics
Check out the space simulator called Vega Strike, modelled after the space simulator games Elite and Wing Commander. It's Open Source too!
If you have ever played Wing Commander, or especially Privateer, and had a feeling of nostalga derived from the you will enjoy these two Vega Strike mods: Privateer Gemini Gold and Privateer Remake!
I'm working on adding multiplayer support this year...
Unread 26-02-2005, 23:24
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
Re: ERROR
Unfortunately, I have to use floating point ^??. If I don't, my accuracy goes WAY WAY down. Even with 4 decimal place accuracy I am still .5 off from my target.
Ok, I figured the cause of the error(unposted .h problem) was the same thing with the .h file. I just got rid of the file because the .c should do everything that the .h would. Here is the new error:
Make: The target "D:\Robot\MyFiles\main.o" is up to date.
Make: The target "D:\Robot\MyFiles\user_SerialDrv.o" is up to date.
Make: The target "D:\Robot\MyFiles\user_routines.o" is out of date.
Executing: "D:\Robot\mcc18\bin\mcc18.exe" -p=18F8520 "user_routines.c" -fo="user_routines.o" /i"D:\Robot\mcc18\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
Make: The target "D:\Robot\MyFiles\user_routines_fast.o" is up to date.
Make: The target "D:\Robot\MyFiles\printf_lib.o" is up to date.
Make: The target "D:\Robot\MyFiles\ifi_utilities.o" is up to date.
Make: The target "D:\Robot\MyFiles\ifi_startup.o" is up to date.
Make: The target "D:\Robot\MyFiles\MATH.o" is out of date.
Executing: "D:\Robot\mcc18\bin\mcc18.exe" -p=18F8520 "MATH.C" -fo="MATH.o" /i"D:\Robot\mcc18\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
90: I_PSTINCFRAM
90: I_IND32RAM16
90: I_MEMBERRAM16
90: I_INDXRAM16
90: I_IND16RAM16
90: I_IDSTK(zp)
D:\Robot\MyFiles\MATH.C:126:Fatal [100] -internal- unable to reduce tree:
Halting build on first failure as requested.
BUILD FAILED: Sat Feb 26 20:22:05 2005
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 26-02-2005, 23:35
Alex1072 Alex1072 is offline
AKA: Alex
#1072 (Harker Robotics Team)
Alex1072 is an unknown quantity at this point
Send a message via AIM to Alex1072 Send a message via Yahoo to Alex1072
Re: ERROR
Originally Posted by amateurrobotguy
I think I made a tiny bit of progress in finding a math.c Only problem is, I get this error.
Make: The target "D:\Robot\MyFiles\user_routines.o" is up to date.
Make: The target "D:\Robot\MyFiles\math.o" is out of date.
Executing: "D:\Robot\mcc18\bin\mcc18.exe" -p=18F8520 "math.c" -fo="math.o" /i"D:\Robot\mcc18\h" -D_FRC_BOARD -Ou- -Ot- -Ob- -Op- -Or- -Od- -Opa-
D:\Robot\MyFiles\math.c:65:Error [1302] old style function declarations not supported
BUILD FAILED: Sat Feb 26 16:30:19 2005
The error is on line 65 ("return(zp->d);"), so I would guess the mplab compiler doesn't support return(a). Try changing the return statement to "return zp->d;"
As is implied above though, using this function may not be a good idea. The pow function is not intended for small imbedded microprocessors and relies heavilly on floating point operations. It is designed for a full size computer. Running this function on the robot controller will slow it down a lot. You can try it and see if anything weird happens, but I would try and find another way to solve the problem, if possible. When you try it, watch out for weird behavior of the robot, that is a good indication that you are putting too many operations into the 26ms loop.
Alex
President
Team 1072 Harker Robotics
Unread 26-02-2005, 23:56
Re: ERROR
I don't think that that is my problem. When I follow your suggestion at the end of the two functions I get this error:. (See my latest post) The line error is the last line of math.c. In the previous and this error, Line 126 is the problem
D:\Robot\MyFiles\MATH.C:126:Warning [2054] suspicious pointer conversion
Assertion failed: 0, file trn18.c, line 2783
abnormal program termination
BUILD FAILED: Sat Feb 26 20:54:17 2005
Unread 27-02-2005, 14:27
Re: ERROR
Hasn't anyone used ceil() or floor or pow()? I just need a math.c with the definitions for C18 compiler or a header or something.
Unread 27-02-2005, 15:55
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: ERROR
I define like this
void Default_Routine(void)
long reduction;
double para;
long nodecimalpara;
long reduction2;
double para2;
long nodecimalpara2;
and get this:
D:\Robot\MyFiles\user_routines.c:239:Error [1105] symbol 'redeuction' has not been defined
D:\Robot\MyFiles\user_routines.c:246:Warning [2058] call of function without prototype
D:\Robot\MyFiles\user_routines.c:247:Warning [2058] call of function without prototype
D:\Robot\MyFiles\user_routines.c:252:Error [1105] symbol 'redeuction2' has not been defined
D:\Robot\MyFiles\user_routines.c:259:Error [1139] integer types required for bitwise XOR operator
D:\Robot\MyFiles\user_routines.c:260:Warning [2058] call of function without prototype
Are you sure you're closing the function?
Unread 28-02-2005, 17:20
Re: ERROR
I have the definitive response from C18 tech support:
I found the functions that you refer to however they are C30 math function found in the math.h for C30 dsPICŪ Language Tools Libraries
The files you inquire about are defined in the dsPICŪ Language Tools Libraries
http://ww1.microchip.com/downloads/e...Doc/51456b.pdf
see page 332 double ceil(double x);
see page 355 double pow(double x, double y);
The functions you can use in the C18 library under math.h
MPLABŪ C18 C COMPILER LIBRARIES
http://ww1.microchip.com/downloads/e...Lib_51297d.pdf
see page 162 float ceil ( float x);
see page 165 float pow( float x, float y);
Unfortunately you cannot use the functions you refer to with C18. They are used with C30.
Basically FIRST stiffed us on the compiler...Pity...I could have made a kick-*** function if I had math access.
Unread 28-02-2005, 17:28
AKA: Alex
Re: ERROR
You could probably still write your own from scratch if you research how the normal computer math library (open source) does it and optimize only to do the operations you need. Also, you might want to consider using a look up table. Searching for look up tables on CD should give you quite a bit of results.
Alex
President
error with adc.h incognito_NICK Programming 2 05-02-2005 23:27
MPLink Error cloudago Programming 2 01-02-2005 23:00
MPLAB build error cabbagekid2 Programming 7 12-01-2005 13:36
PHP and Wiki Error Venkatesh Website Design/Showcase 2 24-07-2004 15:51
EMERGENCY! EPROM FULL error?!? CHSguard72 Programming 2 05-03-2003 20:51
