Go to Post I've got much more out of FIRST ever since I stopped and realized I can gain so much more from trying to improve my current team's situation rather than complain about teams who have more. - AdamHeard [more]
Unread 28-02-2005, 23:55
Herbie698 Herbie698 is offline
AKA: Lunchbox
Herbie698 is an unknown quantity at this point
Stock Frame...
Just a quick question to all the teams...who out there used the stock frame material on their robot? If so, how well does it hold up?
Unread 01-03-2005, 00:16
Dan-o's Avatar
Dan-o Dan-o is offline
Strategist
AKA: Brandon Rudy
FRC #1319 (Flash)
Dan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to beholdDan-o is a splendid one to behold
Re: Stock Frame...
If you're talking about some sort of bar or square stock, our team used welded aluminum 1" square stock with 1/8" walls, and it is stronger than we could've ever imagined. The bot has 36" lengths of which you can stand in the middle and have no deflection. Overall, the square stock treated us very well, and we remarkably easy to use.
Woo Hoo 100th post (I know, come talk when you have 1,000)
'03 - FRC 365 - Driver
'04 - FRC 1370 - Mentor
'05 - FRC 1493 - Mentor
'09-'11 - FRC 2975 - Mentor
'12-'13 - FRC 4029 - Mentor
'15 - FRC 1319 - Mentor
'07-'10 - Judge
Unread 01-03-2005, 00:18
AKA: Lunchbox
Re: Stock Frame...
sorry i didn't specify...i ment the stock material FIRST provided..
Unread 01-03-2005, 00:26
Billfred's Avatar
Billfred Billfred is offline
Re: Stock Frame...
Ah, the kitbot.
1293 went kitbot this year. We've got almost exclusively new people driving it so far (and, even worse, me driving it), and it's held up so far. Then again, we haven't been taking brick walls out.
If I remember right, there's video of Paul Copioli's four-or-so-year-old driving the kitbot around. That should be proof enough.
Unread 01-03-2005, 00:40
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: Stock Frame...
We used the kitbot chasis too, but the arm team wanted to cut the front bar off of the chasis after we loctited the whole chasis, so a guy had to go into it and cut out a part using an angle grinder, and after that day...it has been horribly bending inward...The kitbot chasis is good to use if you don't tweak it that much.
Unread 01-03-2005, 01:20
NoodleKnight's Avatar
NoodleKnight NoodleKnight is offline
24 Hours of LeMons?
FRC #0100 (WHS&CHS Robotics)
NoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud ofNoodleKnight has much to be proud of
Send a message via AIM to NoodleKnight
Re: Stock Frame...
We've taken the kitbot through some crash test courses (Not really), we've had our rookies drive, it, I've driven it like I stole the thing, it's held up very nicely. When I saw the extensiveness of the cheese holing during kickoff, I thought that thing would be flimsy, but hey, it's held up (no dents, but many scratches). Too bad we're not using it, the chassis we sent in looks unreliable (it hasn't been field tested, at all)
WHS/CHS Robotics - Team 100 (2003-2006):
2006- Delphi's Driving Tommorow's Technology @ Davis | Imagery Award @ SVR | 2004- SVR Finalists (w/ 691 and 1280)| 2003- Delphi's Driving Tommorow's Technology @ Sac
Unread 01-03-2005, 07:01
Bcahn836's Avatar
Bcahn836 Bcahn836 is offline
Iraq is fun.
AKA: Brad Cahn
no team (Robobees 836)
Bcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond reputeBcahn836 has a reputation beyond repute
Send a message via AIM to Bcahn836 Send a message via Yahoo to Bcahn836
Re: Stock Frame...
We ummm cut the frame up and used the metal for various brackets and braces for our arm, For our frame well we built a tank.
Unread 01-03-2005, 07:06
Denman's Avatar
Denman Denman is offline
Tie Wrap-Not Cable Tie or Zip tie
AKA: Stephen Denman
FRC #0759 (Systemetric)
Denman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud ofDenman has much to be proud of
Send a message via ICQ to Denman Send a message via AIM to Denman Send a message via MSN to Denman Send a message via Yahoo to Denman
Re: Stock Frame...
we originally decided it looks a bit flimsey (as compared to 1/4 inch steel tubes....) and it has been converted into our trolley...
I am an ex-member of team 759.
759: regional winners with 522 and 233 NYC (2004)
FIRSTWiki.org - Contribute, learn, inspire.
"Teach the way of the GP and the way of the GP shall teach you" - Me
Unread 01-03-2005, 07:15
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
Re: Stock Frame...
We put kitbot together, but it twisted around and was flimsy. We decided to use it for are OI controler's frame, but that was twisting the longer it stayed together. I am personally glad that we didn't use it.
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 01-03-2005, 07:42
sirbleedsalot's Avatar
sirbleedsalot sirbleedsalot is offline
FRC #0939
Team Role: Student
sirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura aboutsirbleedsalot has a spectacular aura about
Re: Stock Frame...
We are using the kit bot frame and have had minor troubles but nothing that could not be solved and we do not have the second angle in the frame or the large bumper up front.
our web site
Unread 01-03-2005, 10:12
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: Stock Frame...
We are using the stock frame with some fiberglass additions, our turret is mounted to it's own frame that is bolted to the main frame. It flexes but that is what we wanted. Still have to finish a few things up at Buckeye. Drive testing went well, lots of tire spin with the stock tires.
Unread 08-03-2005, 12:19
Tom Bishop's Avatar
Tom Bishop Tom Bishop is offline
FRC #0832 (Oscar)
Tom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant futureTom Bishop has a brilliant future
Re: Stock Frame...
We used the kit frame material with welded joints instead of bolting it together and welded 1" box on top for the superstructure. That stiffened it up nicely. Had no problems with it at our regional.
Unread 08-03-2005, 17:02
Captain Rich's Avatar
Captain Rich Captain Rich is offline
I am 245
FRC #0245
Captain Rich is a jewel in the roughCaptain Rich is a jewel in the roughCaptain Rich is a jewel in the rough
Re: Stock Frame...
We used the kitbot, and the gearbox too. In fact, all we did was switch to 6" wheels and move them up for lower ground clearance. It is awesome, and let us drive by the second week. It as enough twist to be good. You want all four wheels driving all the time, so a little warpage is good.
Richtopia Prevails Again!
http://richtopia.vzz.net www.adamsrobotics.com
Unread 08-03-2005, 17:33
ConKbot of Doom ConKbot of Doom is offline
Team Alumni
FRC #1184 (Cobra Robotics)
ConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura aboutConKbot of Doom has a spectacular aura about
Re: Stock Frame...
We used the kitbot stuff for our cart. Our bot was made from 2"x3" 1/4" wall thickness rectangular aluminum tubing. It was heavy, so a little mill work, and we got underweight. But the bot still looks small without the lexan on.
Unread 08-03-2005, 17:35
rocknthehawk's Avatar
rocknthehawk rocknthehawk is offline
AKA: Aaron
FRC #1768 (Robo Chiefs)
rocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to beholdrocknthehawk is a splendid one to behold
Re: Stock Frame...
Team 549 used the kitbot frame this year, but added a 1" aliminum extrusion frame on top. We havn't had any problems with it (we took some very hard hits and also gave a few at BAE). i know of a couple teams there that had problems with theres twisting.
Best frame building material superbeano2004 Technical Discussion 59 29-04-2005 08:43
who has combined PVC tubing for thier frame? Alex Cormier General Forum 8 12-12-2004 19:47
Voltage on Frame Greg Electrical 31 02-03-2004 13:49
Beacon and 10 Point ball PVC frame dimensions MrB General Forum 2 28-01-2004 08:35
Rendering Tips Tyler Olds 3D Animation and Competition 27 16-10-2003 01:32
