Go to Post Team 71: So good at Strategy they already have figured out next years game before the GDC has even met. - IKE [more]
Unread 28-02-2005, 18:08
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
Look Up Tables
First, I would like to say thanks to all the people that give support to me and others on these forumns.
Next, since I can't use math functions, it has been suggested that a look-up table be used. I can make the tables, but how to I read data from them? Like on table 1 find this number. Then from that number, goto table 2 with the same row and find that number.
const int table_length = 18;
rom const int x[]= {0, 15, 30, 45, 60, 75, 90, 105, 120, 135, 150, 165, 180, 195, 210, 225, 240, 255};
rom const int y[]= {0, 15, 30, 45, 60, 75, 90, 105, 120, 135, 150, 165, 180, 195, 210, 225, 240, 255};
Basically I want something like:
Search x(135)
a=x postition
goto y(a)
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 28-02-2005, 18:39
ace123's Avatar
ace123 ace123 is offline
AKA: Patrick Horn
FRC #0008 (Paly Robotics - http://robotics.paly.net/)
ace123 has a spectacular aura aboutace123 has a spectacular aura about
Send a message via AIM to ace123
Re: Look Up Tables
To search for an object in an array, do a small for loop:
int search_in_table_x(int lookfor)
    int i;
    for (i=0;i<table_length;++i) {
        if (x[i]==lookfor) {
            return i;
    return -1;
function Default_Routine(void) {
    int ind, x, y;
    ind=search_in_table_x(135);
    if (ind!=-1) {
        x=x[ind];
        y=y[ind];
        pwm03=x; // then do something using those numbers?
        pwm04=y;
(Check for -1 after using the function.)
I'm not sure exactly why you need a lookup table.
I'm pretty sure that whatever you are trying to do could be approximated faster and better with a small divide by 16 or something.
One thing to remember is that you shouldn't overcomplicate things like this. Something that can be solved with some complex math function with sines and powers or a lookup table could often be solved just as easily with a simple divide by 8 or scaling and adding without a noticable loss in accuracy.
Imagine if you are at the competition and your robot goes crazy. You would not want to debug through loads of complex math functions. It wouldn't be possible except for an extremely obvious error.
You would end up either wasting all of your precious practice day debugging it and getting nowhere or else giving up and making it simple.
-Patrick Horn, Paly Robotics
Check out the space simulator called Vega Strike, modelled after the space simulator games Elite and Wing Commander. It's Open Source too!
If you have ever played Wing Commander, or especially Privateer, and had a feeling of nostalga derived from the you will enjoy these two Vega Strike mods: Privateer Gemini Gold and Privateer Remake!
I'm working on adding multiplayer support this year...
Unread 01-03-2005, 12:02
Squirrelrock's Avatar
Squirrelrock Squirrelrock is offline
I may be teh programmer?
AKA: Keegan
FRC #0414
Squirrelrock will become famous soon enoughSquirrelrock will become famous soon enough
Send a message via AIM to Squirrelrock
Re: Look Up Tables
Search x(135)
a=x postition
goto y(a)
If you're trying to have a table for autonomous points to drive to or some such nonsense, make a separate program to handle the tables on another computer that then inputs those cooridinates to the OI to send to the RC to drive to. (Contact Scitobor 617 for details on this program he's writing.)
If you're using these tables for speed control, then use % of the distance traveled (use an encoder) to determine speed.
If it's neither, I have no clue.
Squirrel
Look what I did to Dave:
Aaacckkk! Guurrkkk! Sssnorrrrkkkkk! Brain ... explode ... will. AAAArrrrggghhh!! Must ... not ... think ... about ... 2007 ... yet. Uuurrgghh!!! Still ... have .... to ... resolve ... how ... to ... pack ... parachutes ... for ... 2006 ... Ooorrrkkggnn!!
Sweet!
The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane.
- Nikola Tesla
Genius might be described as a supreme capacity for getting its possessors into trouble of all kinds.
- Samuel Butler
Unread 01-03-2005, 13:09
Re: Look Up Tables
...Like on table 1 find this number. Then from that number, goto table 2 with the same row and find that number.
Search x(135)
a=x postition
goto y(a)
Your example is probably poorly chosen to indicate what you want. The x and y arrays are identical, so whatever you put in as your search is what you get out as the result.
Lookup tables are most easily used as replacements for a simple y=f(x) computation when f() involves lots of multiplication. I don't know what function you're trying to perform with your pair of tables, but what you asked for reduces to a simple f(x) = x.
Unread 01-03-2005, 17:19
Re: Look Up Tables
Thanks guys for the help. I know exactly what I am going to do to get what I want accomplished. I speak generally because I am kinda a hermit when it comes to giving away robot secreats.
Unread 08-03-2005, 21:50
xchezhd xchezhd is offline
xchezhd is an unknown quantity at this point
Re: Look Up Tables
you could use a little pointer math once you find the index from the first table.
int* y_ptr = &y; // can't remember if you need the & here,
// check during compile
value_from_y = *(y_ptr + index);
    int i;
            return i;
    return -1;
    int ind, x, y;
    if (ind!=-1) {
        x=x[ind];
        y=y[ind];
        pwm04=y;
Unread 09-03-2005, 00:08
ace123's Avatar
AKA: Patrick Horn
Re: Look Up Tables
The code
int val = *((&table) + index);
is equivalent to
int val=table[index];
In fact, I think they compile down to the same code at the end.
This reminds me of an IOCCC entry [hint file] that used index[array] instead of array[index] because the pointer math is in reality the same.
Unread 09-03-2005, 00:14
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
Re: Look Up Tables
The code
is equivalent to
Technically, that should be
int val = *(table + index);
because table is a pointer by default. Writing
int table[];
is just short hand for
int *table;
Sorry for being pedantic but in programming it can be important.
Matt
Large Lookup Tables Mr. Lim Programming 5 16-02-2004 21:30
New Website JamesWu Website Design/Showcase 56 27-12-2003 20:53
Another idea looking for comments archiver 1999 16 23-06-2002 22:01
