Go to Post With people from the high northeast, mid east, mid west and far west all in one hotel room, we had the time of our lives simply by sitting there. - Keith Chester [more]
Unread 01-03-2005, 10:40
Validius's Avatar
Validius Validius is offline
There is a shadow following me.....
AKA: Mark Ratering
FRC #1549 (Washtenuts)
Validius will become famous soon enoughValidius will become famous soon enough
Send a message via AIM to Validius
How did you use the FP motors?
How did you guys use your FP motors?
I drew up a quick CAD diagram of how we did. We were so busy with the bot that we didnt have time to take pictures. Green is the FP motors, red is the winch spindle and blue is the cable. We used a 20" nested ladder.
Tell me what u guys think?
When a sociaty comes to believe that human life is not inherently worth living, it is a slippery slope to the gas chamber. You wind up on a low road that twists past Columbine and leads toward Auschwitz.
-Peggy Noonan
Unread 01-03-2005, 10:44
Best Available Data
FRC #1778 (Chill Out!)
Re: How did you use the FP motors?
We used a Fisher Price to control our second arm joint.
Unread 01-03-2005, 10:49
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We used them in our six motor drive train
Unread 01-03-2005, 10:56
Logan Byers Logan Byers is offline
Roaming Mentor & Referee
no team (Team Indiana)
Logan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud ofLogan Byers has much to be proud of
we do too! 461's six motor drive train
Unread 01-03-2005, 11:20
henryBsick's Avatar
henryBsick henryBsick is offline
Why wait for the last 20?
AKA: Henry B. Sick
FRC #0125 (NUTRONS)
henryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond reputehenryBsick has a reputation beyond repute
Send a message via AIM to henryBsick
We use our FP's to extend and retract on our 11.5 foot arm. Both FP's and their gearboxes turn a spindle that winds and unwinds spectra cable. We can get the arm all the way out in about ...4-5 sec.
edit/
Here is a good pick of the arm and its FP's.
/edit
Mechanical Engineer
Digital Lumens
NU ME: 2011
Unread 01-03-2005, 11:26
Jaine Perotti Jaine Perotti is offline
...misses her old team.
AKA: BurningQuestion
FRC #0716 (The Who'sCTEKS)
Jaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond reputeJaine Perotti has a reputation beyond repute
Send a message via AIM to Jaine Perotti Send a message via MSN to Jaine Perotti Send a message via Yahoo to Jaine Perotti
Team 716 used used one FP motor to drive the joint of our secondary arm.
http://www.chiefdelphi.com/forums/pi...gle&picid=9866
We combined the FP gearbox and the kit gearbox together to create the proper reductions needed to lift the tetras. So far it works wonderfully. The FP barely even gets warm each time we run it. While I wouldn't say it is the most compact arm joint out there, it does the job well, especially for the first time our team has ever attempted to build a complex arm (well, more complex than anything we have done in the past).
Come check it out at UTC, New Jersey, or nats.
-- Jaine
edit: I found some pictures of our arm setup; one is a picture of the KOP gearbox with the drum from the FP gearbox attached, the other is a picture of the FP and its gearbox. The two are put together and...voila!
ID:	3034  Click image for larger version
Florida Institute of Technology
Ocean Engineering, '12
Unread 01-03-2005, 12:37
Validius's Avatar
AKA: Mark Ratering
yea, one of the mentors found some couplers that used to be on an old barbie jeep and we used them for the bot.
-Peggy Noonan
Unread 01-03-2005, 12:46
Billfred's Avatar
Billfred Billfred is online now
How did 1293 use the FP motors?
We used it to add to the mass of our box of motors.
Unread 01-03-2005, 13:12
We used 2 of those babies to power our main arm. Both are coupled into a shared shaft, which has a small sprocket attached. That sprocket then sits on a fixed chain "roller" system. While it may add a little weight, it saves us the frustration of chain tensioners. It also makes for easy swap on/swap off of motors and sprockets.
http://www.chiefdelphi.com/forums/sh...d.php?t=35032&
I dont care what anyone says, the FP motor is one of the best in the kit!
Unread 01-03-2005, 13:25
Jay H 237 Jay H 237 is offline
Down at the railroad
AKA: Jason Hartmann
FRC #0237 (Black Magic)
Jay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond reputeJay H 237 has a reputation beyond repute
Send a message via AIM to Jay H 237
We didn't use them. As a matter of fact we gave them to Tom^ since we have no plans for them.
We only used the FP one year, 2000, to drive a belt and that was it.
2006 Maryland Delphi "Driving Tomorrow's Technology" award
2006 Connecticut General Motor's Industrial Design award
2005 Finalists-----------New Jersey (along with our alliances again, 56 & 303)
2005 WINNERS of the Radio Shack Innovation in Control Award (not once, but twice! )
2004 WINNERS ------ Johnson & Johnson Mid-Atlantic Regional (also thanks to our alliances 56 & 303)
2004 General Motors Industrial Design Award Winners
2004 Archimedes Quarterfinalists (also thanks to our alliances 121 & 386)
NEMO _________ NonEngineering Mentor Organization
"Make it idiot proof and someone will make a better idiot!" - author unknown
Unread 01-03-2005, 13:26
Gene F's Avatar
Gene F Gene F is offline
FIRST Fanatic
AKA: Gene Falendysz
#0343 (Metal in Motion)
Gene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to beholdGene F is a splendid one to behold
Send a message via AIM to Gene F
We have a similar configuration.
- Gene Falendysz
Unread 01-03-2005, 13:30
SteveO SteveO is offline
SteveO will become famous soon enoughSteveO will become famous soon enough
We used the Fisher Price motors to freshen our shop with a plasticy fresh scent and warm our hands when it was cold outside.
Unread 01-03-2005, 14:29
Validius's Avatar
AKA: Mark Ratering
haha
-Peggy Noonan
Unread 01-03-2005, 14:50
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
We actually didnt use them this year. We only needed 5 motors, 4 CIMs to drive, window motor for our pulley to raise our arm.
Unread 01-03-2005, 16:04
Andy A. Andy A. is offline
Getting old
FRC #0095
How did we use the FP motors you ask?
http://www.chiefdelphi.com/forums/pi...gle&picid=9794
-Andy A.
PWM and burning out motors patrickrd Technical Discussion 7 19-06-2003 15:30
Suppose you want seat motors... archiver 2000 0 23-06-2002 22:50
