Go to Post I've got much more out of FIRST ever since I stopped and realized I can gain so much more from trying to improve my current team's situation rather than complain about teams who have more. - AdamHeard [more]
Unread 01-03-2005, 16:22
Alex1072 Alex1072 is offline
AKA: Alex
#1072 (Harker Robotics Team)
Alex1072 is an unknown quantity at this point
Send a message via AIM to Alex1072 Send a message via Yahoo to Alex1072
How to tell when FPs fry?
How do the FPs burn out? Do they give out lots of smoke and make it obvious, or do they sometimes just slowly lose torque. I'm asking because I suspect we partially burned ours out before ship.
Alex
President
Team 1072 Harker Robotics
Unread 01-03-2005, 16:31
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: How to tell when FPs fry?
Both, If they are really fried they smell back long after. They also just don't put out the power of a new one if they are partly cooked. We are going to Buckeye with four spares.
Unread 01-03-2005, 17:26
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
They smell really really bad.
Unread 01-03-2005, 17:57
Woodie Flowers Award
Ken Patton Ken Patton is offline
purple
FRC #0051 (Wings of Fire)
Ken Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond repute
In my experience they actually start to smell before they are fried.
In some cases the plastic fans melt. Once the fan melts you are in trouble because thats what was cooling the motor.
We have had the 2003-style motor smoke, but then still be usable afterwards.
What we use as the F-P test, and what has worked so far this year where we are running the "6V" motors in our drive system - is to touch the motor: if it is almost too hot to touch, then you should stop running it and let it cool. Don't let the motor get too hot to touch - and of course don't stall the darn thing - and you might be able to make it last.
I don't recommend "thermal-shock-in-a-can" either .
Ken
Unread 01-03-2005, 19:06
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Do yourself a favor and get some of the heat sinks mentioned in this thread
Unread 02-03-2005, 08:00
Mike33's Avatar
Mike33 Mike33 is offline
NOOOOOOOOOO! MY LAST YEAR IS OVER!
AKA: Keebler (Elf)
FRC #0033 (Killer Bees)
Mike33 will become famous soon enough
Send a message via AIM to Mike33
they smell bad and/or the famous magic smoke is seen
--"Always bear in mind that your own resolution to succeed is more important than any other one thing." --Abe Lincoln
Final Four in 2005 National Championship
2005 National Team Imagery Award
2005 West Michigan Imagery Award
2005 Detroit General Motors Industrial Design Award
2nd Place in Detroit and West Michigan
"Its a jeep thing, you wouldn't understand"
---copy the jeep and pass it around---
o_o_o_o
./| ,[_____],
|ŻŻŻL--O|||||||O
()_)Ż()_) ŻŻŻ )_)
(originaly made by my friend david)
Unread 02-03-2005, 10:29
The FP motors have a few failure signs, some of those are mentioned above. It is possible when the motor is in stall to only burn one winding. This will give you some false indications in that the motor smells bad but still seems to function. The FP motors have three windings, so one burning reduces the output power by almost a third but since the winding is invariably shorted, the current consumption skyrockets and the heat goes up. You will ask "how you will know if you smell a bad motor?" A burned motor leaves no doubt, it is vastly different than the mechanical, hot oil and brush, smell the motor normally has. A simple visual inspection with a flashlight will show one or more of the following...
1. Loose or cracked fan.
2. A discolored winding compared to the others.
3. Discoloration of the commutator (the copper contacts on the armature)
4. Smoke damage
5. Completely burned commutator and windings.
Arcing is not a sign that the motor is defective, all DC motors will arc at the brushes as part of their operation.
FPs Gone Exothermic Elemist315 Motors 14 23-02-2005 11:01
Burning the FP's SteveO Motors 14 05-02-2005 09:49
How slow is too slow? Joe Ross Rules/Strategy 23 12-10-2004 20:23
Why? Brett W Motors 15 28-03-2002 17:37
