Go to Post Thank you GDC, for keeping everyone honest! - dtengineering [more]
Unread 01-03-2005, 21:32
TEAM 1436 TEAM 1436 is offline
TEAM 1436 is an unknown quantity at this point
two joysticks
does anyone use two joysticks with there autonomus(?) period.
Unread 01-03-2005, 21:35
mgreenley
Posts: n/a
Re: two joysticks
Auton. mandates no operator input, so I would have to ask that you further clarify your question.
Unread 01-03-2005, 21:47
Re: two joysticks
We had our robot running on two joysticks. One for driving and one for working our arm along with a driver on each joystick. The programing mentor came in and told us we couldn't use two joysticks because of a programing issue. When he was programing atonomus it wouldn't work with two joysticks.
Unread 01-03-2005, 21:52
KoRnPoP's Avatar
KoRnPoP KoRnPoP is offline
Webmaster/Driver/Fabricator
AKA: Michael
FRC #1598 (Team Talon)
Team Role: Webmaster
KoRnPoP will become famous soon enough
Send a message via MSN to KoRnPoP Send a message via Yahoo to KoRnPoP
Re: two joysticks
We use two joysticks one for arm operator and one for driving operator and our autonomous works perfectly fine.. so there should be no trouble.
MasonMM's Avatar
MasonMM MasonMM is offline
AKA: Mason Markee
FRC #0118 (Robonauts)
MasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond repute
Re: two joysticks
hmm quite strange of a problem, we always have two joysticsk hooked up to our Operator Interface and our autonomy still works fine. I'm pretty sure teams all around the country dont have any problem with two joysticks and autonomy.
Unread 01-03-2005, 22:03
Re: two joysticks
It sounds like the mentor doesn't fully understand how to do something. Why don't you suggest that he/she post for help in the programming forum. Or there will probably be people willing to help at your regional.
Unread 01-03-2005, 22:19
Shu Song's Avatar
Shu Song Shu Song is offline
Melodious Footware
AKA: *Crash!* Shuuuuuuuuuuuu
FRC #0639 (Code Red Robotics)
Shu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud ofShu Song has much to be proud of
Send a message via AIM to Shu Song
Re: two joysticks
There shouldn't be a problem with two joysticks during autonomous mode. We use 3 joysticks, 2 for drive one for arm, and we don't have any problems with the autonomous code.
Code Red Robotics - Team 639
Ithaca High School| Ithaca | New York | USA | Earth | Sol System | Milky Way | Universe | Some Alien's Locker
WINNER of the 2005 Finger Lakes Regional, thanks to teams 191 and 494.
WINNER of the 2004 Canadian Regional, thanks to teams 33 and 1112
WINNER of Delphi: Driving Tomorrow's Technology Award at the 2007 Finger Lakes Regional.
Unread 01-03-2005, 22:32
JulieB's Avatar
JulieB JulieB is offline
well........
AKA: Just Julie!
FRC #0538
JulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of lightJulieB is a glorious beacon of light
Send a message via MSN to JulieB
Re: two joysticks
all our media day i saw several differant teams using 4 joystick
Unread 01-03-2005, 22:54
KoRnPoP's Avatar
AKA: Michael
Re: two joysticks
Just thinking it over maybe there is a code error or a typeo or something causing the autonomous not to work right. Joysticks should have nothing to do with this.. but one think that could be wrong is that the trim isn't set right on the joystick... but that wouldn't affect just autonomous it would be all the time until adjusted. Just ask someone if the problem continues. Good luck!
Unread 01-03-2005, 23:13
Re: two joysticks
...When he was programing atonomus it wouldn't work with two joysticks.
Excuse the unhelpful response, but that makes no sense in a number of ways. Autonomous control uses no joysticks.
Even if the presense of joysticks mattered, the number should be irrelevant. The signals coming from all four joystick ports will be identical (i.e. inactive) during autonomous mode.
Maybe he's talking about one vs. two joysticks for the drive mode? If he's using the default code as a basis, its color-seeking function assumes single-joystick drive. That can be changed without much difficulty, though it doesn't need to be. The section of the default program running during autonomous is completely separate from the teleoperated mode section, and they don't have to be anything like each other.
Unread 01-03-2005, 23:20
amateurrobotguy's Avatar
amateurrobotguy amateurrobotguy is offline
Lead Programmer/Senior Engineer
amateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these partsamateurrobotguy is infamous around these parts
Re: two joysticks
Why is everyone using 1 for driving and 1 for the arm? Are we the only team attempting to use the triggers/buttons?
I quit FRC over 2 years ago (more if you're reading this past 2010).
Unread 01-03-2005, 23:30
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: two joysticks
Sure, many teams use the buttons on the joysticks. For instance, our throttle has a trigger for turbo mode while driving, which allows for more sensitivity at low speeds without restricting the maximum available speed.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 01-03-2005, 23:33
Alex1072 Alex1072 is offline
AKA: Alex
#1072 (Harker Robotics Team)
Alex1072 is an unknown quantity at this point
Send a message via AIM to Alex1072 Send a message via Yahoo to Alex1072
Re: two joysticks
Because it's hard for 1 person to think about two things at once. At least that's why we're doing it. About the code issue, are you sure your mentor isn't trying to get input from joysticks during auto.? They joysticks are not supposed to work during auto.
Alex
President
Team 1072 Harker Robotics
Unread 03-03-2005, 20:55
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Re: two joysticks
Yeah, we use four josticks(tank drive and two for the arm), and I'm pretty sure that there are no auton' issues.
Unread 03-03-2005, 21:23
bhweezer's Avatar
bhweezer bhweezer is offline
Brandon Higgs
FRC #0364 (Team Fusion)
bhweezer is a jewel in the roughbhweezer is a jewel in the roughbhweezer is a jewel in the rough
Send a message via AIM to bhweezer
Re: two joysticks
We use two joysticks to drive and a joystick for our arm and we haven't ran into any problems. I agree, clarify your question.
Team Fusion (364)
Synergy in Motion
number of joysticks Waste General Forum 21 27-01-2005 15:04
Sophisticated Joysticks WebWader125 Control System 3 03-12-2004 15:33
need joysticks! Tom Bottiglieri General Forum 14 24-02-2004 09:36
AVB joysticks..and other analogue joysticks tml240 Kit & Additional Hardware 6 07-02-2004 12:45
Calibrating speed controllers and joysticks thedillybar Technical Discussion 4 11-02-2002 13:24
