Go to Post Load the whole bot up with all 22 motors, put them all into the drive train. Oh yes. - Grim Tuesday [more]
Unread 01-03-2005, 23:29
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
Re: Static Variables
Originally Posted by amateurrobotguy
If I want to define a variable inside of a function and want it to be available to all functions in the .c file, will static do it?
No, not as you listed it. If you declare a variable inside a function (static or not), it is only available inside that function. The difference is that a static variable declared inside a function will retain its value between calls to that function. So it acts like a global variable but it can only be seen by that function.
If you need to access a variable from many functions you can either make it a global variable or pass it around as part of the function calls.
Need help with Variables ? David Bryan Programming 5 23-02-2004 07:42
Joystick Variables fred Programming 8 20-02-2004 10:58
Simple problem with variables sear_yoda Programming 4 05-02-2004 09:12
VB Program to monitor robot variables DanL Programming 7 15-02-2002 22:35
