Go to Post I'm a drive team coach, they don't eat lunch during competition. - Rick [more]
Unread 02-03-2005, 22:24
Venkatesh Venkatesh is offline
FRC #0030
Venkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to beholdVenkatesh is a splendid one to behold
2002 Default Code
Does anyone have a copy of the 2002 Default Code around?
If so, can I have it?
Thanks,
-- vs, me@acm.jhu.edu
Mentor, Team 1719, 2007
Team 30, 2002-2005
Unread 02-03-2005, 23:40
Bharat Nain's Avatar
Re: 2002 Default Code
This page might be of some help
http://www.ifirobotics.com/first-legacy.shtml
It has all the legacy documents of pre - 2004.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 03-03-2005, 10:11
FRC #0030
I had checked that site, but it doesnt have the 2002 Default Code, only the 2003 materials. The '03 code is usable for what I am planning, but if anyone could tell me where I can get the '02 code, I'd appreciate it.
Team 30, 2002-2005
Unread 04-03-2005, 00:46
ace123's Avatar
ace123 ace123 is offline
AKA: Patrick Horn
FRC #0008 (Paly Robotics - http://robotics.paly.net/)
ace123 has a spectacular aura aboutace123 has a spectacular aura about
Send a message via AIM to ace123
Use the web archive wayback machine.
You probably should try the Jan 14, 2002 to get the best results.
For example, you can download the 2002 default code.
-Patrick Horn, Paly Robotics
Check out the space simulator called Vega Strike, modelled after the space simulator games Elite and Wing Commander. It's Open Source too!
If you have ever played Wing Commander, or especially Privateer, and had a feeling of nostalga derived from the you will enjoy these two Vega Strike mods: Privateer Gemini Gold and Privateer Remake!
I'm working on adding multiplayer support this year...
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Best Way To Insert Autonomous Code Into Default then load help.? :-)? gemccnp Programming 2 05-02-2005 18:58
default code vs. 2.4 stephenthe1 Programming 2 05-02-2005 18:02
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
