Go to Post Instead of prototyping with plywood and machining metal for the final version, they make their prototypes out of sheet metal and machine the final robot out of wood. :) - Chris is me [more]
Unread 03-03-2005, 10:40
TriggsJr TriggsJr is offline
US FIRST made me an Engineer
None #0173
TriggsJr is a name known to allTriggsJr is a name known to allTriggsJr is a name known to allTriggsJr is a name known to allTriggsJr is a name known to allTriggsJr is a name known to all
Send a message via AIM to TriggsJr
Rage Arm Design
If Rage uses no chain or air pistons or cable or rope to extent their arm, how does it extent 12.5ft in less than 4 seconds????
And how can the whole arm assebly only weigh 20 lbs??
Maybe we can find out by watching the videos?
http://www.rage173.org/video.php?catid=28
Hint-there is one fisherprice motor on the arm
arm design Zippiot Technical Discussion 32 27-01-2005 02:56
Arm Design Input -- Four Bar Linkages Sachiel7 Technical Discussion 4 18-01-2005 01:29
pic: arm design Stephen P Extra Discussion 17 17-01-2005 13:53
Telescopic Arm and grabber design help M. Hicken Technical Discussion 13 17-01-2005 12:56
Arm design - rotation mechanism? n0cturnalxb Technical Discussion 6 16-01-2005 18:28
