Go to Post You people are weird... Now if you'll excuse me, I have some code to debug and I need to figure out where to get tank tracks. - sciguy125 [more]
Go Back   Chief Delphi > Technical > IT / Communications
Unread 28-02-2005, 19:25
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Re: How do I save a quicktime .mov file?
Originally Posted by huskyboy
Having trouble downloading these files:
http://www.ats.ucla.edu/stat/seminars/ed231e/
save as lets me download a .mov file but the file is less than 1kb... opened it with text editor and it just has information to another link... tried to use that link to get the file and could not...
any advise?
need from lecture 2 and beyond
Your problem is that even if you use the trick I learned, and shown above, then when you plop the link to the video:
http://www.ats.ucla.edu/videos/edu231e_1_ref.mov
in a browser, then it just links you to a streaming movie file. What this saves as, is just a shortcut to the actual video hidden on the UCLA server somewhere. Even if you right click, and save that link, then.. you still have to connect to watch the movie.
Thus the fact (which I have determined) that streaming media really sux.
Even a little program I wrote doesn't work to grab it.
To DL the movie, you will have to gain exclusive access to the UCLA server that the movie is hosted on from what I can tell.
But then again..
I'm not sure about QT files. Maye someone else can help you better.
Unread 03-03-2005, 13:58
huskyboy huskyboy is offline
huskyboy is an unknown quantity at this point
But then again..
THanks for your help.... anyone else able to capture this video for me?
Unread 18-03-2005, 13:12
amitpg78 amitpg78 is offline
amitpg78 is an unknown quantity at this point
Hi,
I have the same problem but of a different type.
The Quicktime movie opens up inside a Javascript window.
I am trying to copy the movie but that option is disabled when I right click on the movie.
How do I save the movie.
Please suggest.
Thanx
Ciao
Unread 18-03-2005, 14:12
MrToast's Avatar
MrToast MrToast is offline
I named Greg Needel's cat!
AKA: Dave DeLong
no team (Rhode Warriors)
MrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud ofMrToast has much to be proud of
Send a message via AIM to MrToast
Right click in the window, view page source. Look through the source until you find the .mov link. Copy that link, paste it into a new window, then Save the page.
HTH,
Dave
(#121, 2004) Archimedes semi-finalists with 237 and 386! I had an awesome time guys, and thanks for the hat!
(#121, 2004) BC5 semi-finalists with 190 and 1027! Awesome time! We went further than I thought we could! Thanks for all your help w/ our transmission!
(#121, 2005) Galileo quarter-finalists with 47 and 203! Thanks for all your support through the stress!
If it moves and it shouldn't, use duct tape.
If it doesn't move and it should, use WD-40
"It'll all work out in the end, and if it doesn't, it's not the end." - Jeff Bullock
Unread 18-03-2005, 17:33
jdiwnab's Avatar
jdiwnab jdiwnab is offline
Really the Inventor Guy
AKA: Bryan Hartley
FRC #0617
jdiwnab is a jewel in the roughjdiwnab is a jewel in the roughjdiwnab is a jewel in the rough
any advise?
Like Elgin said, it's a streeming video. Meaning that the video is downloading to your cojmputer as you play it and then going away. it saves just enough in a buffer so that it plays smooth-ish. But the buffer doesn't stay. There are programs that you can get (can't think of any now) that will save streeming video for you. but the .mov file that you want isn't availible in any standard way. And like Elgin said, Streeming video sucks
Proof that Macs will win the platform war: How did Scotty know how to use MacDraft in Star Trek IV?
// random()
I have 100 gmail invites. PM me if you want one.
If they want us to think outside of the box, why do they make us fit in a 38x28x60 inch box?
Beware of Geeks bearing GIFs
Help me test my server software
Unread 18-03-2005, 17:39
activemx's Avatar
activemx activemx is offline
A M X
AKA: Akshay Dodeja
activemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of lightactivemx is a glorious beacon of light
Send a message via AIM to activemx Send a message via Yahoo to activemx
The simplest way to save a qucktime file is to click on the triangle button on the bottom right of the control bar. Then click save as quicktime movie. The feature only works on the quicktime full version.
2005 - Present - FIRST Volunteer(Inspector, Ref, Judge)
2000-2004 MVRT 115
File Sharing and Revision Tracking Madison FIRST-related Organizations 14 04-06-2003 18:01
QuickTime or .MOV to AVI or MPEG archiver 2001 2 24-06-2002 02:00
Dashv2.ocx dependency file now available archiver 2000 0 23-06-2002 22:00
Improving PBASIC: Request for Comments Greg Ross Programming 19 16-02-2002 22:14
