Go to Post Once this competition is over, we should donate all of these Poof balls to daycares, elementary schools, neighbors; all the little kids. It would make us look good like, "Here's our Toys for Toddlers gift from us upstanding citizens. And we build robots." - atomikitten [more]
Unread 03-03-2005, 22:52
Burg's Avatar
Burg Burg is offline
I'm my own idol
AKA: Nick Burgwin
#1620
Burg is an unknown quantity at this point
Robot Pit Lift
I was wondering if using the pneumatics from the kit to build a cart for the robot would be possible. The idea would be to build an electric pump truck, in theory. We would power the wheels using electric motors, always on full power, just turned on/off through a power button. But to lift the robot + platform up to amost 4' with pneumatics? How possible is that?
You could start at the minimum height of...2', and use a cylinder with a 12" push, gear it in a way that it will lift double that, with a 130 pound weight ontop. Am I crazy, or is it realistic with the pneumatics supplied?
Thanks!
Unread 03-03-2005, 22:59
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Re: Robot Pit Lift
i think its very possible. To be easy on your pneumatics, i would suggest you use 4 cylinders.
If you want to start at the hieght of 2' you can order cylinders of 24" in length( not throw) the throw should be around 21"22". This way you can almost go upto 4'. 4 cyclinders should have no problem lifting a 130 lb platform upto 4'. Thats only about 43 lbs per cylinder. You can use extra air storage tanks, because this shouldnt be a problem in this case. You will have to seldom fire up your compressor. Any questions are welcome, post some pics when done, when/if you take on this project and finish it.
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 03-03-2005, 23:22
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
Re: Robot Pit Lift
Alternatively, you could use a heavy duty scissor lift as seen in older car jacks. The problem with using pneumatics is that they're bouncy unless you use a lot more force than you strictly need to.
Also, I'd be wary of running the cart driving motors at full speed all the time. It will either be too slow at some point or too fast. If you don't want to use a full blown control system, look for a heavy duty rheostat. Say a wall light dimmer rated for 50+W. Then you can "dim" your motors and control the speed. Only in analog.
Unread 03-03-2005, 23:35
Burg's Avatar
I'm my own idol
AKA: Nick Burgwin
#1620
Re: Robot Pit Lift
How would you power the scissor lift? Using a motor? Which kind?
And the dimmer idea sounds cool, but my intentions were to run the motors at half speed by reducing the voltage/current. And keep it at one speed, all the time, with just a button to turn on the motors. I like you're idea though.
And the 4 cylinders I shall look into. I could lift at all four points to reduce any shakes, no?
Thanks guys.
Unread 03-03-2005, 23:46
thoughtful's Avatar
Re: Robot Pit Lift
yes, the dimmer is a good suggestion otherwise u will have no control whatsoever.
This year we have looked extensively into pneumatics, they can be very stable if you make them, specially when you have no storage limitations. You can even have multi-positioning( having the lift stop any where you want). cylinders with 1 1/2" bore should be sufficient enough. There will be very little shaking if any.
The scisor lift can be either motor or pneumatics powered. A motor will give you much more control, and various positions very easily. If you do decide a scissor lift i would suggest motors. However,the scissor lift has its dowsides too, but if you are only looking for a 4' extension it should be sufficient.
06-Team 1219 Mentor
Unread 03-03-2005, 23:52
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Robot Pit Lift
You need something like this http://www.harborfreight.com/cpi/cta...emnumber=46604
but a little smaller.
As a note, that vehicle looks very unsafe/unstable on that thing.
EDIT: Here's one more the size http://www.harborfreight.com/cpi/cta...emnumber=41145 but it is still too heavy and too expensive.
Unread 04-03-2005, 00:00
Burg's Avatar
I'm my own idol
AKA: Nick Burgwin
#1620
Re: Robot Pit Lift
Wow, that is exactly what I'm looking for, except I don't intend on buying anything. But how does the hydrolics work on that thing...I can't even see anything hydrolic on it. Care to explain?
Thanks
Unread 04-03-2005, 00:06
Mark Pettit's Avatar
Mark Pettit Mark Pettit is offline
Addict
FRC #0991 (The Dukes)
Mark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to allMark Pettit is a name known to all
Re: Robot Pit Lift
With that much weight going up and down on whatever kind of lift you're creating, make sure you keep everyone clear of that thing while it's activating. That could hurt (or worse)!
Mark Pettit
Team #991 - The Dukes
Brophy College Preparatory
Phoenix, Arizona, USA
THE DUKES: Humans Competing In The Unlimited Class
Unread 04-03-2005, 01:15
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Re: Robot Pit Lift
Hey, our team was also thinking of a lift somewhat like that one Sanddrag. We were going to use 4 cylinders we ordered and maybe even two compressors, probably 2004/2005 to power it. The dual compressor action will totally be overkill, but will also be really cool. But for powering it, I was pushing for using an idea for the drivetrain another member of our team had for the offseason to build, but we didn't get around to doing it, but then another guy wants to just tow it in on his barstool racer he's building.
Edit:
And more info is below.
Unread 04-03-2005, 01:19
Manavapor Manavapor is offline
Manavapor is an unknown quantity at this point
Re: Robot Pit Lift
my team is currently working on a lift using the pneumatics from this years kit. I have been developing the idea for a year now and i have decided to use a scissor type lift. We ordered 3 2" bore 24" stroke cylinders for the lifting and we are going to use telescoping steel square bar on all the corners to prevent wiggle. We are also thinking of running 2 compressors on it
Heres a very crude drawing made in ms paint.
http://img159.exs.cx/my.php?loc=img1...ntitled1re.png
And now i took the time to make a little nicer one in photoshop. I tried to make a top view one bt i totally botched it. hope this helps.
[IMG][/IMG]
Unread 04-03-2005, 07:46
Re: Robot Pit Lift
Guys,
I have to put a big caution here. Pneumatics operate like right now, while hydraulics can have some control. (It's all in the valves) I would caution against using something that you can't stop once it starts. I saw a team a few years ago that had a pneumatic actuator on each wheel. When they hit the button, the whole frame and robot jumped up two feet. Knocked one of their pit guys over it was so fast. When a hose popped off and dumped the robot on the floor, they finally stopped using it.
As to using a dimmer, those are only designed for lighting at 120 volts AC and won't work at all on 12 volts DC. A variable speed control from a DeWalt drill (if you are using the NBD trannys) might work for each driven wheel. A foot operated pump up platform is a great idea. Anything that you can do to get the robot up to working height will save your back in the pit as long as you can get it down to where the robot fits through the doors.
Unread 04-03-2005, 09:31
Re: Robot Pit Lift
Well I was thinking an old-style rheostat dimmer, which is just a big variable resistor, which should work fine, really. I'll agree that newer kinds of dimmers don't have a chance of working. I was just trying to come up with a cheaper easier option than an entire control system. One fixed speed just seems like a bad idea. Either you'll be in a rush and it's too slow, or you'll be in traffic and it'll be too fast. At the very least, make up some voltage dividers and have 2 or 3 speeds and a multi position switch.
As to actuating the scissor lift, I'd go with a lead screw and a motor turning it. I was specifically thinking of a device the Mythbusters used in the ceiling fan episode if you've seen it. This too would be a good place to have speed control.
Finally, whatever system you use, you might want to think of a way to lock it in place. Better safe than sorry and all that.
EDIT: This is what I'm talking about: 200-Ohm 50-Watt Rheostat
Unread 04-03-2005, 10:00
Re: Robot Pit Lift
Here's a speed control http://www.harborfreight.com/cpi/cta...emnumber=43060 but it is only rated for 15 amps, and being from Harbor Freight, I would trust that to be the real maximum capacity.
Unread 04-03-2005, 10:14
Re: Robot Pit Lift
I'm tempted to say that thing is AC only since it has three prong plugs all over the place, but it's rated in VDC. I'm forced to conclude that I have no earthly idea how it works or if it would work for 12VDC.
Unread 04-03-2005, 10:22
NickNielsen's Avatar
NickNielsen NickNielsen is offline
#1336 (Untouchables)
NickNielsen is an unknown quantity at this point
Re: Robot Pit Lift
Let me add to Al's caution. If you use pneumatics to activate any kind of load-bearing lift, do not depend on the pneumatics alone to hold the load while you work. Include some kind of mechanical support to prevent your lift from falling unexpectedly if a hose or component fails--think of it as jackstands for your robot.
Please, for safety's sake, if you want a maintenance stand and lift for your robot, get one of the many that are commercially available. Don't build your own!
<Edit>To use a single rheostat to control your motors, you will have to calculate the total power consumption of all four motors, then obtain a rheostat able to absorb that power. For the CIM motors provided with the 2005 KOP, you will need a rheostat that can handle the stall current of 133A (1600W) per motor. Again, the best bet is a commercial model.</Edit
Systems never work the first time; complex systems never work properly.
Corollary: If it works the first time, it won't work the way you expect it to...
Pneumatics Team Leader
Question: What was the first FIRST competition you attended? JVN General Forum 182 25-01-2016 08:24
How much do you design before kickoff? Allison K General Forum 19 07-12-2004 21:32
things to keep in mind while in the pits.. coreyjon Technical Discussion 20 25-10-2004 15:25
Kamikaze Robot Strategy... Joe Johnson Rules/Strategy 30 07-04-2002 21:42
Calling all Lawyers... ...Define "all parts" Joe Johnson General Forum 10 13-03-2002 15:12
