Re: can't get R/C controller to work with EDUbot
figured it out, thanks! our EDU controller was loaded with the IR beacon code from last year. after reloading the default, it works. now to take out the limits of the outputs in programming and make the arm move correctly... >.>;;
| Speed controllers won't communicate w/robot controller | steven114 | Control System | 12 | 03-02-2005 21:26 |
| not quite sure...speed controller...spike. | tophq | Programming | 8 | 26-03-2004 13:43 |
| Can you use PWMs (Red or Blue) with the edubot controller? | Dr.Bot | Robotics Education and Curriculum | 3 | 04-12-2003 23:51 |
| EDU R/C Based Robot | Venkatesh | Technical Discussion | 2 | 02-12-2003 15:20 |
| Optical sensors with EduBot | Gui Cavalcanti | Robotics Education and Curriculum | 5 | 02-03-2003 10:05 |
