Go to Post After all, each day is fresh with no mistakes in it [yet]. - atomikitten [more]
Go Back   Chief Delphi > Technical > Robotics Education and Curriculum
Unread 03-03-2005, 03:59
sweet-chan sweet-chan is offline
sweet-chan is on a distinguished road
can't get R/C controller to work with EDUbot
we plugged in the motors to the PWM outs and the ones from the reciever to the PWM in. the reciever is recognizing the transmitter because the radio light is green but nothing moves when we move the joysticks... we're using default code since we havent tried to reprogram it. can someone please help? thanks!
Unread 03-03-2005, 19:28
Re: can't get R/C controller to work with EDUbot
You have your motors are plugged into pwm01 and 02?
4 wire cable w/black wire on outside?
Radio receiver wires in correct orientation (black on receiver to black on EDU)?
Receiver 1 connected to R/C PWM input 1, etc?
Fully charged 7.2v battery?
Unread 04-03-2005, 01:35
figured it out, thanks! our EDU controller was loaded with the IR beacon code from last year. after reloading the default, it works. now to take out the limits of the outputs in programming and make the arm move correctly... >.>;;
Speed controllers won't communicate w/robot controller steven114 Control System 12 03-02-2005 21:26
not quite sure...speed controller...spike. tophq Programming 8 26-03-2004 13:43
Can you use PWMs (Red or Blue) with the edubot controller? Dr.Bot Robotics Education and Curriculum 3 04-12-2003 23:51
EDU R/C Based Robot Venkatesh Technical Discussion 2 02-12-2003 15:20
Optical sensors with EduBot Gui Cavalcanti Robotics Education and Curriculum 5 02-03-2003 10:05
